How do i remove fog lamp?
Old 03-14-2016, 07:25 AM
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
Default How do i remove fog lamp? 'UPDATE'
Do i need to take the bumper of or what?
If thats the case how do i remove the bumper.
Old 03-14-2016, 07:48 AM
rice_rocket88's Avatar
My Ride: 2008 535xi
Engine: n54
I'd love to know myself because my lens is pretty crusty like yours. I reached in there this weekend from the back to change the fog lights and didn't see a good way. I didn't have the car jacked up or the wheel off so I couldn't take a good look. I'm assuming you'd have to pop it out of the bumper while it's off unless you can reach through the back to get it off, then once you're there you could take that housing out.
Edit:
Just started searching for replacement housings.. looks like those LCI ones are full pieces. Two bolt holes to hold it on .. not sure how to access them, if they are bolted to the frame, or bolted to the bumper cover. If it's the latter I'm sure you could screw it off from the back but I have a feeling it's bolted to the frame itself.
Old 03-14-2016, 07:54 AM
RIHI's Avatar
My Ride: BMW
You can reach it through the back by removing the wheel liners. At least, that's how I did mine.
Old 03-14-2016, 12:56 PM
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
Edit:
I will wait until Saturday to try and remove it from the back.
Old 03-15-2016, 05:04 PM
RIHI's Avatar
My Ride: BMW
You can also remove the headlights and the fog lights are very accessible from there. It takes two minutes to remove the headlight.
Old 03-15-2016, 07:53 PM
E60Japanese's Avatar
My Ride: E60 2006 sedan auto
I hope you got it out okay!
But both people are right. There are two ways
remove the wheel and unscrew your wheel arch inner skrt
or remove the headlight
both are very quick and easy
good luck
Old 03-16-2016, 03:04 AM
My Ride: 2008 535xi
Engine: n54
I see responses about the bulb... If I misunderstood it sounded like he wanted to remove the whole unit, and had already changed the bulb before..
good luck
Old 03-16-2016, 03:11 PM
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
good luck
The headlight i remove many time, i will remove the wheel when new fog lamp arrive.
Old 03-16-2016, 03:13 PM
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
Yeah the bulb i done that already, i have led bulbs.
I see the lamp have to brackets, i will just guide my way to them and get it remove.
Old 03-16-2016, 07:20 PM
BostonJon's Avatar
My Ride: BMW 530xiT (E61)
I have a pre-LCI 07, but I was only able to access the driver side fog by removing the headlamp. on the passenger side, i was not able to access the fog light with the headlamp removed.
Quick Reply: How do i remove fog lamp?
