How do I know if I've bent or damaged a rim?
Old Dec 26, 2005 | 11:55 AM
jet190rs's Avatar
I live in Manhattan in New York, and roads are very bad here. Every street has potholes and bumps. To my knowledge, I have never bent or damaged a rim. But maybe I have and I just never realized it. Sorry if this is a newbie question but how do I tell? What are the signs? Can I tell by looking at the rim? Just see if the spokes are the same shape? Or look "inside" the rim, at the round surface behind the spokes? If a rim is bent, can I feel the difference while driving immediately after hitting a pothole?
Old Dec 26, 2005 | 01:18 PM
ipse dixit's Avatar
A tell-tale sign of a bent/damaged rim is chassis shaking and/or steering wheel vibration at moderate to high speeds (e.g. >40 mph).
Old Dec 26, 2005 | 02:57 PM
wolverine's Avatar
If you can't see a dent in the rim, and it's holding air, then check it at high speed. If there is no vibration at hwy speeds, then your rim is probably fine. If you feel some vibration, or there is a slow air leak, then you may have a bent rim. Be sure to look at the inside of the rims when the car is up on the lift.
Old Dec 26, 2005 | 06:05 PM
znod's Avatar
[/quote]Right, a bend might be confined to the inside. I had a pretty badly bent rim once, on the inside, that caused no ill effects so I left it alone.
Old Dec 27, 2005 | 04:36 AM
pennetta's Avatar
I developed a vibration in the steering wheel, and the dealer confirmed that one of my front wheels was slightly bent. However, the vibration turned out to be warped brake disks which were replaced and cured the vibration problem.
I looked at the wheel but could not see that it was bent.
Old Dec 27, 2005 | 05:00 AM
znod's Avatar
Good. If you don't notice negative driving affects/can't see a bend, then it is not bent.
Old Dec 27, 2005 | 06:18 AM
pennetta's Avatar
Generally the first place to bend is the bead area, thats where the tire seats on the rim.
Old Dec 27, 2005 | 12:42 PM
jet190rs's Avatar
Sorry what is the bead area?
Is it the part that attaches to the spokes? Like the "lip" on a deep dish rim?
Old Dec 27, 2005 | 01:40 PM
ipse dixit's Avatar
[/quote]
Not the lip. It is, however, the part that attaches to the wheel -- see pic below. A tire's bead allows it to clamp firmly onto the wheel ...
Old Dec 27, 2005 | 07:25 PM
jet190rs's Avatar
[/quote]
How many beads does a tire have?
And how do you locate them when you're looking at the side of your car?
