How do I know if the e60 comes with Active Steering?
Old 07-18-2006, 04:39 PM
certify's Avatar
I know its the steering feel but how would I know if its really there? The salesman told me its there... but I don't know cause I don't want to be cheated of fooled before buying a used e60 525..
Kind of wired question actually...
Old 07-18-2006, 04:42 PM
jet190rs's Avatar
well besides the obvious stuff like asking to see the window sticker, etc....
if it has AS, then you cannot turn the steering wheel a full 360 degrees to either side from dead center
Old 07-18-2006, 04:50 PM
certify's Avatar
Oh... Is there anthing I can check on the engine bay e.g. DSC unit?
Old 07-19-2006, 12:35 AM
colejl's Avatar
All pretty hidden AFAIK - it's a very compact unit and it's not obvious from looking, i've tried! Best way is to check lock-to-lock...
Old 07-19-2006, 01:22 AM
certify's Avatar
Ok..
So what you are saying is that lock to lock cannot be more than 360 degrees at non motion.. right?
Old 07-19-2006, 02:04 AM
aybeesea's Avatar
Originally Posted by certify' post='312552' date='Jul 19 2006, 10:22 AM
Ok..
Some articles I've read say 1.5 turns. Others say two.
ABC
Old 07-19-2006, 03:15 AM
certify's Avatar
ABC
I'm a little comfused... now...
Old 07-19-2006, 03:21 AM
zag
zag's Avatar
My Ride: e60 530i - SOLD!
Get the sales chap to punch the VIN and list the option reference from computer.
Old 07-19-2006, 03:24 AM
certify's Avatar
Maybe I should do that... Is the VIN located on the windscreen?
Old 07-19-2006, 03:28 AM
colejl's Avatar
Ok. 'Normal' steering has no variable gearing so the steering wheel has a lock-to-lock of about 3 turns. With 'Active' steering the physical lock-to-lock is under 1 turn regardless of speed. At low speeds the additional effort is provided by the system to turn the wheels (about 10:1) and at higher speeds the extra effort is not needed (about 20:1) - continuously variable in-between.
So if you do a slow test drive and see how much you can turn the wheel (Stationary too but it's not a good idea) You can turn without moving the position of your hands on the wheel, i.e. not push-pull stuff
Quick Reply: How do I know if the e60 comes with Active Steering?
