How do i get to these strut bar Bolts?!?! Help?
Old Oct 5, 2011 | 07:52 AM
skeematics's Avatar
My Ride: 550i Manual Sport
Engine: 4.8 L N62 V8
I previously posted that i was hearing a "cracking" sound from the front of my car when driving on uneven surfaces. Thanks to your help, you guys found the problem to be related to loose strut bar bolts. This makes sense to me.
The problem is now, how do get to bolt # 2 and # 3. Refer to the attachment. Bolt #2 and #3 are tightly tucked under paneling.
Attached Thumbnails How do i get to these strut bar Bolts?!?! Help?-e60-strut-bar-4-bolt_1.jpg
Old Oct 5, 2011 | 07:54 AM
rctmthouse's Avatar
attachment???
Old Oct 5, 2011 | 07:55 AM
skeematics's Avatar
Originally Posted by rctmthouse
attachment???
Sorry, uploaded attachment
Old Oct 5, 2011 | 08:50 AM
skeematics's Avatar
Anyone? Please help...
Old Oct 5, 2011 | 08:53 AM
pjinca's Avatar
Remove the microfilter boxes, remove the base, then you can get to the bolts pretty easy.
Old Oct 5, 2011 | 08:57 AM
umichchris's Avatar
My Ride: ///M5 BEAST
its pretty easy to get at those rear bolts.
that rubber trim you see there, lift it up with your hands gently. it snaps right out of place. underneath that rubber gasket/housing/trim you will find the two remaining bolts.
im going to sand/prime/paint my sway bars this weekend and i have already scoped out the access points. good luck, should be easy!
Old Oct 5, 2011 | 08:59 AM
pjinca's Avatar
See? Just do what Chris said. If you need a DIY for it, search for how to change the brake fluid, the steps for removing that cowl section are there.
Old Oct 6, 2011 | 11:21 AM
skeematics's Avatar
I just completed the job, took me about 15 minutes. Thanks for everyone's help.
bestofthebest
Oct 2, 2015 03:21 PM
vince_e60
Sep 23, 2015 02:25 PM
DetailersDomain
Detailing Forum
Sep 22, 2015 03:59 PM
derooster
Sep 22, 2015 10:10 AM
umnitza
Sep 2, 2015 11:28 AM
