Hi guys,
Is there a way to check the level of transmission fluid in our cars? Can someone knowledgeable shed some light? Thanks in advance! |
The transmission fluid cannot be checked. It doesnīt need to be changed either. Itīs for life. Unless you have a leak or something. Then probably you will have to replace the seals and fluid (a lot of money each littler goes around $43 and the car uses 10 lt. if not mistaken).
Originally Posted by MrEJW
(Post 1307818)
there is no dipstick or way to do it through idrive. there is some kind of specific procedure that can be done with the car on a lift though (tranny has to be at certain temp, then they open it up and somehow check it). seems like a dumb design. replacing a automatic tranny these days probably costs as much as replacing an engine, and you can't check the fluid lever?
Originally Posted by SilberGrauE60
(Post 1307821)
Keep in mind, "life" in BMW terms is probably 75,000 - 100,000 miles (this has been mentioned on this board before), so you will need to eventually change your fluids.
(Post 1307821)
To check transmission fluid level:
1. Vehicle must be on level surface (or raised in air level). 2. Transmission must be at proper specified temperature (I believe the temp range is between 35 and 45 degress celcius. Monitored via INPA or other similiar program). 3. Shift transmission through gears pausing at each gear (including reverse). 3. Fill plug removed. Fluid is at proper level when fluid is at bottom of fill plug hole and transmission within proper temp range and in park. Lifetime fluid does not exist unless you consider the failure point lifetime...which will happen sooner than it needs to if you dont change the fluid. Change fluid every 80k miles or more often. |
Originally Posted by DavidF
(Post 1307891)
1. Vehicle must be on level surface (or raised in air level). 2. Transmission must be at proper specified temperature (I believe the temp range is between 35 and 45 degress celcius. Monitored via INPA or other similiar program). 3. Shift transmission through gears pausing at each gear (including reverse). 3. Fill plug removed. Fluid is at proper level when fluid is at bottom of fill plug hole and transmission within proper temp range and in park. Lifetime fluid does not exist unless you consider the failure point lifetime...which will happen sooner than it needs to if you dont change the fluid. Change fluid every 80k miles or more often. Can anyone recommend a good indy shop in Chicagoland? I bet stealer will charge a lot of $$ for flush/pan gasket change. |
