How to adjust front fog lights?
My Ride: E60 525i pre LCI
Hi, my 2006 E60 525i failed a warrant of fitness inspection because the front fog lights were aimed too high.
They look fine to me. I have pulled the plastic grille off which reveals a single screw, which I'm assuming changes the angle.
Is this correct? And if so, what is the standard DIY method of measuring the angle of the beam?
Thanks
Thanks
My Ride: e60 530i e21 320i
Model Year: 2005 1981
Engine: M54 M10
Here's a link to a BMW Technical Information Service document that is everything BMW. Flip through it and like the procedure for adjusting your lights and you will be good to go.
https://www.newtis.info/tisv2/a/en/
carid
Jan 6, 2015 02:01 AM
Bigfoot
Oct 22, 2006 04:38 PM
