5Series.net - Forums
-   -   hood not closing properly (https://5series.net/forums/e60-discussion-2/hood-not-closing-properly-17165/)
Jeffs Oct 13, 2005 11:45 PM
I just finished installing black kidney grille for my car. I had to take the metal plate covering the radiator out at first and I put everything back in perfect order, no damage, not even a single scratch. I checked to make sure every nut and bolt is tight. however, when I close the hood, there seems to be about half an inch opening between the hood and drivers side taillights. Passanger side is totally fine. What has gone wrong?? Anyone experienced this before? Anything I missed out? Don;t want to bring car to dealer yet because its expensive...
zag Oct 13, 2005 11:56 PM
[snapback]184066[/snapback]
Chances are the hood catch is not engaged properly. Have you tried to drop slam close the hood again from a foot height? Don't tried to press down the hood you will dent it.
Jeffs Oct 13, 2005 11:59 PM
Yes I did that. First I closed the hood nice and easy by slightly touching the hood and let it close by itself which dod not work. then I slammed it from a foot's height and di dnot work as well. I got mad and pushed it hard. Well, i am in my garage now and thank god there was no dent. :help: :help: :help: :help: :help: h
zag Oct 14, 2005 12:11 AM
Originally Posted by Jeffs' date='Oct 14 2005, 03:59 PM
Yes I did that. First I closed the hood nice and easy by slightly touching the hood and let it close by itself which dod not work. then I slammed it from a foot's height and di dnot work as well. I got mad and pushed it hard. Well, i am in my garage now and thank god there was no dent.? :help:? :help:? :help:? :help:? :help: h
[snapback]184073[/snapback]
OK. have you checked the hood catch height for both the left and right one to see if they are equal height? They are located on the hood itself!
if not remove the plastic cover and turn the catch CCW to lower a notch of two and tried again. Adjust them till you satisfied with the gaps.
Also check the catch lock to see if they are on open position just like those on the door.
Hope this help!
Merv the Derv Oct 14, 2005 02:26 AM
I know it sounds daft but have you left any tools or screws under there?
amigo525 Oct 14, 2005 03:51 AM
Well, I did not change the grill or anything, and I was having the same problem with my hood. Believe it or not, i never noticed. My little 5 yrs nephew was the one who told me "hey uncle...is your hood open?" I asked why "he said..can you see the difference" ---
and that is the end of that.
Then I took it to the dealer for service..did not even remember to mention the hood to them..when they gave the car back to me..it was perfect.
..and that is all I have to say about that.
Remind me of forrest gump :think:
Jeffs Oct 14, 2005 05:36 PM
[snapback]184110[/snapback]
nope i did not leave any tools. Went to dealer to set up appointment, and he said since I was the one tinkering wth the hood I'll have to pay...this sucks.....im gna try nad solve this problem by tuesday...dammit :angry:
Bimmer32 Oct 14, 2005 06:52 PM
Originally Posted by Jeffs' date='Oct 14 2005, 08:36 PM
[quote name='Merv the Derv' date='Oct 14 2005, 06:26 AM']I know it sounds daft but have you left any tools or screws under there?
[snapback]184422[/snapback]
[/quote]
You probably know this already but there are "2" hood latches; one on the right and one on the left. In addition, the front hood on the hood. Open and reclose from 6 in to 1 foot drop should fix it.
EBMCS03 Oct 14, 2005 07:50 PM
First do your catches work? Check by trying to lock them with a screw driver... BE sure to release them again after they lock else if you try to close your hood like that you'll be in a world of a suprise...
If they both lock then try adjusting the D latches... on the hood... by unscrewing the black cover and then turing the D latches counter clockwise to make them stick out more.
http://forums.e60.net/uploads/post-937-1123028268.jpg
http://forums.e60.net/uploads/post-937-1123028316.jpg
AC_S5 Oct 14, 2005 10:55 PM
There's some problem with this new hood design and I think BMW know about it already so they ask you did you temper with the hood if you did you are going to pay for it for sure. When I was in the dealer checking the car out before buying the one on display did not close properly either and the salesman just pop the hood and drop it down hard and I mean hard. Then the hood pop back into place. That's why I don't buy demos or display car :thumbsdown:
