Hong Kong E60 sub-Forum
Old 07-03-2011, 06:36 PM
  #33431
pinguhk's Avatar
My Ride: Mini Cooper
Originally Posted by RC3
Do I need to take them out before dealer service?
yes
if you don't they will make a record that you have mod the engine and if any thing goes wrong then they will not fit it for free.
Old 07-03-2011, 06:40 PM
  #33432
pinguhk's Avatar
Originally Posted by Jacky328
Dunno the actual gain in power, any bros here have use it before? and please comment
Does the stock filter also reusable? Or at least recyclable?
But, in any case you can get it replace for free under first two-year warranty,
K&N is about 3 to 5 hp depends on the engine.
OEM filter can not use again so not green at all, need to change every year.
Old 07-03-2011, 06:42 PM
  #33433
pinguhk's Avatar
Originally Posted by Small Tomato
No, I feel you since I have the same issue ... would probably do a Inspection II from BMWHK later this year to see what is their answer ...
all they will do is change the pads for you they will not fix it.
If they can not fix my then I will just change to my Hawk pads and the SS lines later
Old 07-03-2011, 08:28 PM
  #33434
kcleung's Avatar
start/stop will give better emission data but I am sure this feature will put extra wear on the starter motor, battery and engine wear so holistically whether its actually greener is a big ?
Originally Posted by pinguhk
I dont think it can, they trying to make the car more green.
Old 07-03-2011, 08:35 PM
  #33435
kcleung's Avatar
to be honest, the diff is so small I could hardly feel any. over the long term you can save $ and better for the env but cleaning the filter takes time (it needs to be completely dry b4 applying the oil) so it could be a bit of trouble for some.
Old 07-03-2011, 11:22 PM
  #33436
pinguhk's Avatar
Thats how they make $$$ :thumbsdown:
Old 07-03-2011, 11:25 PM
  #33437
pinguhk's Avatar
yes it take a long time
The trick is to clean it in the summer
I will clean my in 2 months time when the sun is the hottest and it will dry up very fast.
today is a good day to clean it.
Old 07-04-2011, 03:29 AM
  #33438
Jacky328's Avatar
Everyone has the Power Box said they loved it. Much like the SB. Also will have better gas milage. Only option which has HP and torque gain for our NA engine.
Sounds too good to be true!
But, seems impossible as you can not get more power by using less gas, can't you?
(so long as the machine is not tech improvement, but with HP increase mod)
So I think there must consume more gas despite how small to gain more power, which you should bear
Old 07-04-2011, 03:35 AM
  #33439
Jacky328's Avatar
I was too ignorance to clear it my self in past 3 years :thumbsdown:
This is first time to hear to clear air-filter at ourself!
Wouldn't it harm engine by not clear at all?
Old 07-04-2011, 03:45 AM
  #33440
Jacky328's Avatar
Originally Posted by wnshie
My pana has this feature too, yes, you can turn this feature off with porsche
Yep
At least, in certain extent saving some gas to contribute envir,
help cooling down engine heat, he he
Seriously, your overheat was help by refill that magic pink coolant?
Quick Reply: Hong Kong E60 sub-Forum
