Hong Kong E60 sub-Forum
Old 05-22-2011, 06:09 PM
  #32731
pinguhk's Avatar
My Ride: Mini Cooper
Originally Posted by bbl
So it is not leak wind, only need aline?
Or if it just the noise only?
I bought my new seal. But no time to replace it. I must replace it this weekend. After the air scoop.
yes please do replace it this weekend!!!
we all what to know if it will fix the nosie from the air passing over the sunroof.
Old 05-22-2011, 06:55 PM
  #32732
bbl
bbl's Avatar
My Ride: 525i
okok,
i will do it at the weekend.
but i will reset the sunroof today to see if it helps to cut the noise off.
Old 05-22-2011, 08:13 PM
  #32733
pinguhk's Avatar
okok,
How do you reset the sunroof?
Old 05-22-2011, 09:37 PM
  #32734
newbie2's Avatar
your sunroof will not leck wind or water for a long time.
I have never herd of E60 do this on the forum.
what it will be is the sunroof glass will be off set from the frame so it need to be alined again.
this is very common with the sunroof.
When traveling at high speed (100KM/hr), there is some wind noise appearing but I think this is normal for most car, right?
Old 05-23-2011, 12:06 AM
  #32735
billhk's Avatar
My Ride: carbonized MB coupe
i had my sunroof seals changed on my old e60 twice under warranty, it was ok until i opened the sunroof
a few times, it's a typical fault of the tolerances between the hard cover and the rubber rim ,around 80km up there is some buffeting sound just have the under shade on and forget about it.
Old 05-23-2011, 01:25 AM
  #32736
wnshie's Avatar
Song Bill, my man! You rarely surface recently, how are things? When do I get to see your new hot 4 wheels babe?
Old 05-23-2011, 05:16 AM
  #32737
pinguhk's Avatar
only on old cars but I think BBL has fix it today he will upload a link.
try it out to see if there is any more nosie after the reset
Old 05-23-2011, 05:29 AM
  #32738
mark_hk's Avatar
If you check the forums, alot of ppl have the issue with the noise and wind buffeting from the sun roof......
Alot of ppl also replaced seals...
Old 05-23-2011, 05:41 AM
  #32739
billhk's Avatar
busy man,
kids, and its my busiest time of the year bro.
wheels - u must have heard, i was forced to take them off as it was too "FEI JAI"
jeez!
what abt you when is your Mansory aerofoil coming????
Old 05-23-2011, 07:27 AM
  #32740
bbl
bbl's Avatar
My Ride: 525i
please check if it can be open
File Type: pdf
Quick Reply: Hong Kong E60 sub-Forum
