Hong Kong E60 sub-Forum
Old 04-23-2011, 09:42 AM
  #32321
MMBMW's Avatar
Alive again and run great except some minor problem to be fixed by AK. Engine light on while step to high RPM than getting hard to go higher than 3000RPM.... Should be fixed.
Muffer sounds fantastic! Thanks for all devils and it's a good choice.
Old 04-23-2011, 09:43 AM
  #32322
MMBMW's Avatar
Old 04-23-2011, 09:44 AM
  #32323
MMBMW's Avatar
Old 04-23-2011, 06:31 PM
  #32324
newbie2's Avatar
You should seriously consider to cut a little bit on the rear bumper and get the pipes closer to the body, then it will be great
Old 04-23-2011, 06:34 PM
  #32325
newbie2's Avatar
Maybe Vanos issue, need to connect to computer to check.
You go down tomorrow? I properly go down for finish my work! Damn beautiful sunshine today.
Old 04-23-2011, 11:37 PM
  #32326
MMBMW's Avatar
Yes, properly will go and check it out. May be Wax tooooooooo
Old 04-24-2011, 12:08 AM
  #32327
mark_hk's Avatar
where u gonna go wax it??
Old 04-24-2011, 01:37 AM
  #32328
MMBMW's Avatar
Front door of AK's shop by myself. Would you like to help? Good for your health too. Ha HA hA!
Old 04-24-2011, 03:37 AM
  #32329
bbl
bbl's Avatar
My Ride: 525i
Originally Posted by pinguhk
I just use water and a micro fiber cloth, no need to lam wa bow, only use this 1st time.
After just use water
Icic.
Thanks alot
Old 04-24-2011, 03:43 AM
  #32330
bbl
bbl's Avatar
My Ride: 525i
use "Lam Wai Bo" to clean the leather???? Don't scare me! Especially E60 leather is quite soft and good (compare than E class). Use special leather cleaner la...just $1XX and can use for a year.
It is normal leather won't be able to do. U will see what is the different nxt time
Quick Reply: Hong Kong E60 sub-Forum
