Hong Kong E60 sub-Forum
My Ride: Mini Cooper
I change to borsh in my last car
how much are these? They cheaper than borsh?
your current blade doesn't work?
if it didn't wipe the glass clean
you can try this
go and ask for the very fine sand sheet
run it though your wiper blade a few times
try the outcome on wind screen
if not clean enough just run a few times more
btw please let me share my experience playing on wiper blades
i had tried out a few different cost range wiper blades
the result is, all the rubber finally gonna oxide and they will turn hard and don't clean the screen probably
especially when you always park your car under the sunlight
so what I recommend is , get a mid range price wiper and replace them whenever they turn bad
that should give you the best result for windscreen cleaning
and of course, you need to take care your windscreen as well![Cool](https://5series.net/forums/images/smilies/cool.gif)
you can try this
I use the 3M blue clay to clean it, which also works.
My Ride: '08 530i Luxury LCI
you can try this
you can try this
so you need to use a fine sand paper to refurbish it to a straight blade so the water won't escape
the sand paper only cost a few dollers
why not try it out for free on a unusable wiper blade?
but of course, it depends, if your case is harden rubber blade then it can't help
Just the bolt to tighten the wiper arm is loosen. I think it was due to my wiper jumping on the wind screen and cause too much vibration on the bolt, then loosen.
the damaged wiper no longer stright
for the wipers it is $480 for the stepwgn :thumbsdown:
