Hong Kong E60 sub-Forum
My Ride: '08 530i Luxury LCI
My Ride: 530i
Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
C16 means you can change third party same size disc (with drill hole or slot) but not OEM. Just liked he did before.
My Ride: 530i
If some one have this device, then end-up result may different.
http://www.youtube.c...esh+div-1r-2-HM
Attachment 102171
Attachment 102171
Yeah you can opt for drilled/slotted discs as long as they are the same diameter as your current set up. If you want bigger discs, then you will have to upgrade to bigger calipers...!
totally agree, the GTI driver is reckless while the e46 driver is plain stupid. but I dunno what appledaily judged that the e46 driver is the one who are in fault.
The Golf is a real fcuking idiot to sqeeze between the bus and the E46 in the first place!! The Golf driver is so stupid! And frankly I can't understand why the E46 had to make that turn... becuase if the E46 intentionally make the Golf crash into the bus, then I would expect the E46 to run away since E46 didn't get any impact, but the E46 stopped... very strange and stupid drivers.
I guess:
different disc diameter will take differen bridges cos the position of caliper will be different.
if the disc is too thick or thin for a certain caliper, you will need to change the caliper as well.
you can always find a disc that fit your current brake settings if you only want to change the disc.
damn it I want one! but need to get ready for jail if got caught.
http://www.youtube.com/watch?v=PBHcmRTnUeA&feature=rec-LGOUT-exp_fresh+div-1r-2-HM
Attachment 102171
Attachment 102171
