Hit a small pothole and now my RFT Dunlops have a bulge on them, would i have to get them replaced or can it be repaired ? :(
Since it's a sunday i cannot take it over to the BMW service centre, for now i have put a jack on the car so that the damaged tyre stays above ground with no pressure on it. What other precautions should can i take, should i inflate or deflate the tyres by a few psi? I want to get my facts correct about the repairing possiblities because i am sure the dealership is going to pressuade me for a tyre change even if it can be repaired. can someone shed some light on how to determine if the tyre is still repairable? Also how much does a single new RFT Dunlop 225/50R17 cost? Should i switch over to non RFT instead? |
1 Attachment(s)
Since it's a sunday i cannot take it over to the BMW service centre, for now i have put a jack on the car so that the damaged tyre stays above ground with no pressure on it. What other precautions should can i take, should i inflate or deflate the tyres by a few psi? I want to get my facts correct about the repairing possiblities because i am sure the dealership is going to pressuade me for a tyre change even if it can be repaired. can someone shed some light on how to determine if the tyre is still repairable? Also how much does a single new RFT Dunlop 225/50R17 cost? Should i switch over to non RFT instead? EDIT: If there was a chance of it getting repaired, keeping it at normal inflation is a MUST. Hopefully you have TPM ('06 or newer) since it can tell a few psi drop. I would not drive on it very far if the buldge is signficant. I KNOW you are better off getting it replaced ASAP. I think a weakness in the RFT design is the chance of the sidway seperating or tearing away from the stiff RFT sidewall core. With Bridgestone RFTs on a 650i, I hit a pothole at 80mph and tore the sidewall. I didn't know about it for 20 miles until I got a low pressure warning. It was 4:45 on a Friday. Being out of town with a full weekend planned, I was VERY fortunate to find a replacement tire and got it replaced for $500 at a local BMW dealership!!!! Attachment 44120 The question remains whether the pot hole would have hurt a regular tire, or the rim, and whether I could have had a blowout and accident. I'll never know but am glad to be on non-runflats in the 550i for their better ride quality. |
Thanks for the prompt reply Richard
I have an Lci 525d just 3 months old done about 6000kms there is no tear in the sidewall unlike u r s but there is just a prominent bulge. No low tyre pressure warning so is there a chance of repair since no air loss has taken place? I do plan to shift to non rft once these wear out but I guess replacing all low is too early due to low milage |
The exact same thing happened to me on my 2004 car with runflats. I had to get a new tire for sure but I'm convinced that the stiffer sidewall of the runflat helped to protect my wheel from any damage...
https://us.i1.yimg.com/us.yimg.com/i...icons7/104.gif Whoa!!! Replace man. You might have to pay a bit more, but peace of mind is priceless. The last thing you need is a failure at high speed. Even with RFT's, a failure at higher speeds could lead to instabilities. Repair = https://us.i1.yimg.com/us.yimg.com/i...ticons7/42.gif.
Since it's a sunday i cannot take it over to the BMW service centre, for now i have put a jack on the car so that the damaged tyre stays above ground with no pressure on it. What other precautions should can i take, should i inflate or deflate the tyres by a few psi? I want to get my facts correct about the repairing possiblities because i am sure the dealership is going to pressuade me for a tyre change even if it can be repaired. can someone shed some light on how to determine if the tyre is still repairable? Also how much does a single new RFT Dunlop 225/50R17 cost? Should i switch over to non RFT instead? this happenned to me twice last December and I had to change 2 tires. I do not think repair should be an option for you. |
Happened to me 3 times on my right front tire. Lucky I bought tire/wheel insurance. It needs to be replaced :(
If memory serves... you had a bubble on one of your new 2008 19" non-RFTs too Rudy! |
