2004 545 manual transmission. at around 70 mph, I get a vibration from the rear of the vehicle. not violent , but kind of like a butt massage. shifter and passenger seat shake a little. I've been through rims,hub rings, tires, balancing, etc. everything looks good and tight as far as suspension, but the vibration is still there. anyone have this and get it corrected? I'm thinking of a lot of different things as to what it can be but don't want to just go and replace part after part. thanks
Originally Posted by pauliehcfr
(Post 1317129)
A worn rear shock could be to blame it could be the rear wheel bouncing up and down that you can feel.
(Post 1317129)
Thanks for the replies folks. They are 18" TSW wheels in a staggered set up. The old wheels had cracks and bends and were the result (I think) of the vibration originally. New rims and tires and vibration was better. Vibration came back a few months later and one of the rears had a bubble. Replaced tire and all was well until recently. I was thinking that one of the rear shocks might be worn causing the wheel to hop. I actually replaced the driveshaft a year ago and it didn't help. The hub rings are plastic and correctly sized.
(Post 1317235)
Think I found it. Let me know what you folks think. Crawled under and checked the rear bushing that supports the differential. It rubber has separated from the metal and has som play in it.
check those upper arms too
Its either #14 guiding, 19 wishbones or 2 balljoint http://realoem.com/bmw/diagrams/r/j/178.png |
I also noticed that the rubber boots on the wishbones are torn, they're tight, but leaking grease.
| All times are GMT -8. The time now is 04:29 AM. |
