High beam on when turn signal (blinkers)
My Ride: BMW F10 528xi
Model Year: 2013
![Red face](https://5series.net/forums/images/icons/icon11.gif)
Hi,
Today I saw that my high beams are going on for a sec. when I turn my signal to right. When I turn my signal to left, it is normal. When I turn on my lights and turn to right, it is also normal. So when my lights are off and i turn to right, my high beams are going on for 1 second.
I looked in LMA in ncsexpert, but I didn't see anything strange... Could someone help me with this problem?
My Ride: 2008 535i
Are you sure you are not confusing "high beam" for your corning light??? It is the same bulb. Took me 3 months to notice this on my car as well. The light goes on on the side that your are turning. Also if you put the car in reverse they both go on for some reason.
My Ride: 535XI
Engine: N54
My inner lense only turns on when turn signals are on and when reversing, my DS1 is my High and low beam.
Model Year: 2013
Maybe the stalk, but when I turn on the lights, the problem isn't there; only when the lights are completely off.
Model Year: 2013
I want to thank Kewill, he tried to solve the problem using NCS, but it didn't worked. He put KOMBI and LM to default, but the problem is still showing. So.... What could be te problem.
