5Series.net - Forums
-   -   HID Fitting guide (https://5series.net/forums/e60-discussion-2/hid-fitting-guide-103940/)
Muppet_Man Sep 12, 2010 07:55 AM
45 Attachment(s)
I love my 535D, but with all the amazing extras it was fitted with, it has really surprised me that it doesn't come with Xenons. Further more, the headlamps it does have on dipped beam, are woefully inadequate. I live in the middle of nowhere down a shady lane in Suffolk, and with the nights drawing in, I didn't want the drive home to be illuminated by the current candles.
So, I ordered a set of HID's off of E-Bay and have decided to fit them today. I'm sure that many of you have done this before, and it's not difficult, but just in case someone is out there and is a bit worried about how to do it, I've photographed the procedure and included it below.
For those of you in the know, my apologies for the boring blog entry.
OK, so start with one slightly grubby 5 series E60/E61
Attachment 111104
NOTE* As a general rule I would advise removing the headlamp dipped beam moisture covers, removing the old lamps, and then plugging in the new ones while just resting them on the top, don't even bother to remove the new lamps from their protective plastic shroud, as they'll be safer that way. This way you can then start the car making sure that your kit does not bring on the lamp warning light failure. Kits all seem to say that they won't do this, however by checking first, you can save a whole lot of hassle by finding out their OK now, rather than when you've spent a couple of hours fitting them. You'll only need to try them for a minute as you don't want to get them hot.
You'll also need to following tools. A Torx T30 screwdriver bit and driver. Either a long screwdriver T30 or a 1/4" drive ratchet set with a long extension and an 8mm socket. A small flat blade screwdriver, a pair of pliers, a drill and a 25mm wood bit. Finally, a small container for the bolts and a cat to kick in case it all goes horribly wrong.
Get the bonnet up and let's see what we need to do.
Attachment 111105
First, remove the top two Torx bolts that hold the headlamp top in place.
Attachment 111106
Note, one is longer than the other. All other bolts are the same size.
Attachment 111107
Then, if you look down behind the headlamp, you'll find two more torx screws, but these ones have an 8mm head on them. You don't need to remove these, just undo them a few turns to allow the headlamp to slide out later.
Attachment 111108
Attachment 111109
Now remove all of the torx screws that hold down the bonnet slam panel. There are about 14 of them.
Attachment 111110
Lift out the bonnet release cable from its retaining clip and then lift up the slam panel by sliding it back slightly and then lift.
Attachment 111111
Put the slam panel onto the engine.
Attachment 111112
Underneath you will now see two more torx screws that are the final ones that hold the front grill assembly.
Attachment 111113
Slide the headlamp forward as far as it will go, then pull the outer side forward enought to get to the connectors at the side of the headlamp assembly.
Attachment 111115
First remove the small lower connector by squeezing the edges together and pulling.
Attachment 111116
Then remove the much larger connector by sliding it away from the headlamp which will release it from its latch.
Attachment 111117
Now gently pull forward on the upper edge of the front grill and slide the headlamp slightly to the side and then out.
Attachment 111118
Repeat for the other side.
Attachment 111119
In my case, close the bonnet slightly so that my Llamas don't come along and nick all the bolts.
:unsure:
Attachment 111120
Get the headlamps resting on a good size table or work surface with a soft towel in place so as not to scratch the lenses.
Attachment 111121
Attachment 111122
Remove the dipped beam lamp rear moisture seal plug by turning it and unscrewing it.
Attachment 111123
Remove the original lamp by twisting it a quarter of a turn anti clockwise. Note how the lamp sits in the hole, position wise, by looking at the cut out position on the lamp bezel. You'll need to fit the new lamp in the same position, however as it's not held in only one position like the original lamp, you'll need to make a mental note which way it goes.
Attachment 111124
Remove the plug from the back of the lamp. On the end of the plug you will see a small steel clip. Using the small screwdriver, prise the clip from the plug.
Attachment 111125
For ease, keep the plug out of your way with a bit of string or a lacky band. The steel clip must be used again to hold in the new lamp.
However, because of the design of the replacement lamp, the small lug on the clip will need to be flattened out with a pair of pliers.
Attachment 111126
Attachment 111127
Once flat, it's ready for fitting.
Attachment 111128
Slide the lamp into the clip backward (make sure you don't touch the lamps as the natural grease from your fingers will cause the lamp to get hotter than it should and blow) - you could cut the wires (the plugs are to large to go through the clip), however the lamps operate at a high voltage, and if you don't get the connections correct, they will bring up a lamp fault on your dash. Also, if you ever need to change a lamp, you'll need to cut them again. Make sure that it sits correctly in the clip and that the two wires have ample room so as not to become trapped.
Attachment 111129
Now is the bit I found to be the worse. Lower the new lamp into place making sure of the position as mentioned earlier (cut out on the lamp back faces up) and then slide the clip under to two retaining lugs, just as it was with the original lamp.
Attachment 111130
This bit is tricky only because the new lamp bezel is thicker than the original, so you have to push quite hard and turn at the same time and the clip is very sharp, so it digs into your fingers. Plus if you've got mauler hands like mine, they don't fit in the hole very easily!
Once done though, you'll easily see whether you've got it right or not as otherwise it won't sit flat.
Look through the front of the headlamp and make sure you lamp orientation is correct (the exposed arc filament of the lamp should face almost directly downwards).
Attachment 111131
Plug in the new cables to the original plug - the positive (red) of the new wires fits into the yellow of the original plug and the black into the other. Push the plug inside of the headlamp back, there is plenty of room in there, but just make sure it cannot stop the headlamp tilting if you have self levelling lights.
Attachment 111132
Now drill the hole in the centre of the moisture seal plug. Drill a smaller hole than you appear to need so that when the grommet goes in place it creates a moisture seal or else your headlamps will fog up when it's damp. I used a 25mm wood bit, but this may vary from brand to brand of lamp kits.
Attachment 111133
Once done, pull the new cables through and pull the grommet into place.
Attachment 111134
You should end up with a nice neat fitting.
Attachment 111135
Get the headlamps back to the car. Starting with the inner part of the headlamp, once again gently pull on the grill to allow the headlamp to be slotted back in. There's not a great deal of room, but you'll find it does go.
Attachment 111136
Attachment 111137
Attachment 111138
As soon as its started, go to the outside of the lamp assembly and put your plugs back in. Large one first, then the small one (if you try the other way round, the small connector fouls the larger one, stopping it going in).
Now, making sure that the headlamp is sliding back into place with the two torx screws at the back of the headlamp, gently put the headlamp completely back.
Attachment 111144
Put the two grill support bolts back into place and tighten and then replace the bonnet slam panel, making sure to slide it under the clip as seen below.
Attachment 111139
Attachment 111140
Fit back and do up all of the bonnet slam panel bolts and the two per headlight top bolts and two per headlamp hidden bolts. Gently push back on the headlamp as you tighten the bolts to make sure it's back flush in it's original position.
Attachment 111141
Attachment 111142
Attachment 111145
Refit the bonnet release cable into its retaining clip.
Attachment 111143
Plug in the new lamp leads to the ballast starter that is supplied with your new HID hit.
Attachment 111146
Attachment 111147
Fit the ballasts in a safe place behind the headlamp where they cannot fall and where the connections face down, so that any water splashing on them will naturally drip back off of the connectors. Hold them in place with cable ties, double sided stickies or by the screw plates supplied with some kits.
Attachment 111148
Have one final check that you've done up all of your bolts. Checking the lamps should be no hassle as ideally you've done as suggested and checked that right at the start.
Attachment 111149
Hey Presto, nice white and bright Xenon lamps. Now I just need to clean the damn thing!
:dance:
jay77 Sep 12, 2010 08:23 AM
Nice write up and pics! :thumbsup:
Take some shots at night and post them up too.
bens1088 Sep 12, 2010 08:29 AM
Very thorough! Good job!
jaycal3 Sep 12, 2010 08:54 AM
Awesome write-up and great pics. This is the kind of thread the forum needs more of! :twoup:
Good job! :clap:
healthservices Sep 12, 2010 09:23 AM
Great write up a mod should transfer this to the DIY section. https://5series.net/forums/public/st...fault/clap.gif
For added clarity at night, you can do the same for the fogs lights. https://5series.net/forums/public/st...t/thumbsup.gif
BLooD Sep 12, 2010 09:58 AM
NIce job doodehttps://5series.net/forums/public/st...ault/twoup.gif, I`m still jealous of that colourhttps://5series.net/forums/public/st...ult/worthy.gif, keep it safe as I may come down to Suffolk and swap yours for mine while your not lookinghttps://5series.net/forums/public/st...ault/devil.gif j/k https://5series.net/forums/public/st.../whistling.gif
nomis_nehc Sep 12, 2010 10:46 AM
What color is that? I assume it's E61 only?
BLooD Sep 12, 2010 10:48 AM
No, we think it`s Indianapolis red but it needs confirming, if it is it`s the only one in the uk.
Muppet_Man Sep 12, 2010 01:18 PM
Thanks for the comments.
I'm at the dealers next Thursday, so hope to get the colour certified then.
Like the idea of Xenon fogs, may give that a go next.
Going to fit a Gateway 500 soon also, so may put down all the fitting for that so long as I'm not repeating what someone has already done.
Getting my new non run flats on Saturday, so am looking forward to improved ride. I'll also do a four wheel track and camber check as I am able to borrow some gear.
Not sure what else I really need?
I'm sure something will come up :)
BLooD Sep 12, 2010 01:46 PM
Errrrr! How about an m-tec kit?
