help to troubleshoot misfire on N62TU
Hey guys I need some directions on how to troubleshoot the misfire on my wife's 550i. Periodically I get check engine light with 29CE and 29CC errors.
I have checked the spark plug on cylinder 2 and ingition coil. No issues were noted and no oil on the spark plug. I have swapped spark plug and ignition coil on cylinder 1 and 2. Today my wife started the car and it had a really rough idle with 29CE and 29CC errors thrown. Since the problem didn't follow the spark plug/ignition coil I can conclude it is not ignition coil/spark plug related. What should be my next step? This issue is pretty rare and seems to happened only on cold start. I drove the car to work today and no problem with idling. I have BMW diagnostic software (inpa, rheingold...). The car mileage is right under 40k miles. |
Originally Posted by tpaxadpom
(Post 1594254)
Originally Posted by Gee_115
(Post 1594269)
Could be the fuel injector. Not sure exactly how you diagnose that without taking it out. Fuel injector shouldn't go bad at 40k though.
(Post 1594276)
Thank you. I agree fuel injectors used on N62TU seemed to be pretty solid comparing to those used on N54 and other turbocharged motors. I wonder if CCV can cause this, the strange thing is that it is only cylinder 2 that is throwing the error and it happens very rarely.
Help with cold start resulting in misfire on 545i - Bimmerfest - BMW Forums |
