Help..! Sudden Diesel Smell
My Ride: 530D M Sport Auto. Carbon Black with Beige Leather
After a bad week with everything going wrong, I was driving home this evening and whilst coming off the motorway a heavy waft of diesel smell came into the cabin. As I was close to home I carried on for a couple of miles with the windows down for fresh air. There were no errors and no loss of power just a nasty smell of diesel.
Having removed the engine cover there was a little smoke from the top of the inlet manifold - diesel mist it appears.
The area around a couple of the recessed manifold bolts next to the injector rail was wet so I dabbed a tissue on it and it was clear so definately not oil.
I gave it a good clean and started the engine again but could not see any fresh diesel deposits so I guess it must have come out under high load pressure from somewhere??
Any ideas of likely possibilities??
I'll leave the car at home tomorrow as I dont want to risk any further damage.
530d M Sport 2004 - Swirlflaps Removed...
Thanks Guys
Thanks Guys
My Ride: Bmw 530d 2004
My strong guess is a cracked exhaust manifold. Here's a great thread about it!
Maybe worth to check it out. Good luck with the issue!
Originally Posted by 530DMSport' post='922429' date='Jun 24 2009, 11:22 PM
Thanks Anzafin.. but how would a cracked exhaust manifold cause diesel to be on the inlet manifold???
edit: Or do you mean that you spotted actually diesel splashes (the fuel) on your intake manifold? Sorry it's my English...
Originally Posted by Anzafin' post='922431' date='Jun 24 2009, 09:24 PM
Hmmm... Check your air tubes; EGR, turbo.... ![Think](https://5series.net/forums/images/smilies/imported/think.gif)
My Ride: BMW E61 525DSE Auto Touring.
2004 54 plate
Metalic saffire Black,
Active Steering.
18 Inch Style 124 Alloys,
falken 452s
Beige Leather
Dark Poplar Wood Trim
xenon bulb upgrade
blutooth phone prep
check your fuel return lines
Do you mean one of the the following items..
Real-oem
My Ride: E60 530d M-Sport
Can I presume you did the swirl flaps yourself ??
Its possible you never seated one of the rubber sealing rings properly when you refitted the inlet manifold ? and its only just starting to let go ?
Just a guess mate.....or a loose stud maybe from when you did the same job, do you use thread lock on those things ??
2004 54 plate
Active Steering.
falken 452s
Beige Leather
xenon bulb upgrade
blutooth phone prep
Originally Posted by 530DMSport' post='922591' date='Jun 24 2009, 10:51 PM
if performance is not affected just thought it might be return pipes
