Help!! replaced Trans solenoids and now doesnt crank
I replaced the transmission solenoids on the valve body in my car, after putting everything back together, the car only "clicks" when pushing the start button. I used INPA to diagnose, and have the following faults,
DME/DDE CD99 D4 DME/DDE CD9E 54 DME/DDE CD9D 54 DME/DDE CDB0 54 the battery was reading at 12.5, any ideas will be appreciated!!! PS 2006 525i |
Originally Posted by cnjames6
(Post 1596903)
It sounds like you never fitted the plastic slide for the gear select into its proper position when you refitted the valve body
You will need to remove the filter and you will be able to see it on the drivers side of the valve body |
Originally Posted by E60Japanese
(Post 1596915)
Yes that's right
If that's not in the correct place you will not be selecting the correct gear so it won't start The only other issue you may have is that you never fully engaged the big electrical plug after installing the valve body although I think i would check both to make sure |
