Help please! Ticking sound coming from passenger bank of engine
Hey guys, hoping you guys could help me out.. I'm getting a ticking sound coming from the passenger bank side of the engine (BMW 550i, 68k miles), and had two independent shops check it out and one said the car was misfiring due to injectors, and the other said the injectors were fine and the car is not misfiring and to not change the injectors. I am getting no CEL light, car drives fine and MPG is fine.. the ticking sound usually comes after the car is completely warmed up, and when in gear and accelerating or revving in neutral. It is engine speed dependent, so the faster the engine revs the more ticking sounds I get..
Let me know if any of you guys have any insight! greatly appreciated..
My Ride: 2006 BMW 550i
does the tick get louder with more of a load on the engine? like louder while accelerating at high rpm versus cruising at high rpm? then it could be an exhaust leak at the exhaust manifold.
if the noise is always consisitent with rpms regardless of other scenarios, then it may be mechanical in nature.
you could get a stethoscope from your local parts store to try and track the noise.
My Ride: 2004 545i Sport
1998 M3
Could be a noisy injector, which is nothing to worry about and not uncommon. The guy I bought my M3 from replaced all the lifters because of misdiagnosed injector noise.
My Ride: 2014 535 Alpine White
1998 M3
You can diagnose injector noise by revving the engine and listening for the ticking when the throttle is lifted. OBDII cars cut off fuel to the engine during coastdown by turning off the injector pulses. So if the ticking goes away momentarily when the throttle is lifted then it is injector noise.
Seems to have no ticking when the throttle is lifted. Ticks are usually only heard under load, under low speed acceleration, or revving the car, all when the car is warm only. The independent shop says I should change out my injectors before I possibly flood my engine w/ fuel.. how likely would this happen? I only have 67k miles!
1998 M3
My Ride: Na
Try turning your ac on. It may be the ac compressor. I have a ticking noise, and when I turn on ac it goes away. I had a local mechanic check it out, without me telling him I think it maybe the ac compressor, he recommended that, the ac compressor is the cause of the noise.
Latest update: Crevier BMW said it wasn't worth it to start tearing down the motor to see where the sound is coming from due to no CEL light and no other issues besides the ticking sound. They said it seems like it is coming from the heads / valvetrain area, however just to keep an eye out on it and keep driving. Annoying to say the least, however nothing I can really do unless I want to spend thousands to tear the motor down...
Another shop said its coming from the VANOS as well.. and also to not worry about it and to continue driving.. I had German Castrol syntec 0W-30 as my last fill and just changed it to stock BMW 5w-30 and sound is still there as well.
If anyone else is experiencing such a sound, please respond if any issues developed! thanks
