Help please car wont start
So my car is in the body shop and they have been running it with low fuel and it finally ran out. So they went to go get gas and now the car wont start. It cranks but just wont start. I checked all the fuses and there all good. Any help will be greatly appreciated thanks in advance.
Mine us manual so I put it in 2nd gear while coming down the hill and after some tries it worked.
Check engine light had came on ut went away as soon as engine started
HTH
Originally Posted by turbo_mustang12' post='910667' date='Jun 13 2009, 05:35 PM
Thanks man. Somebody told me it could be the fuel pump? Idk..
It should pressure up then stop. Try that cycle several times if you haven't already.
Also. I've read in a post about the "fuel pump purge" noise that occurs when you close the
door after stopping the engine and getting out of the car. My car makes that noise.
If the pump has run dry for an extended period it may be damaged.
Not sure how to reset this on a BMW.
My Ride: 2008 535i w/ Sports & Permium Pkg. Silv/Blk
2008 VW R32 w/Nav.
1992 VW Corrado Silv/Blk-retired
2001 530i Sports/Premium-retired
Originally Posted by Ellicit' post='911034' date='Jun 14 2009, 01:55 AM
air in the line maybe?
