Help Please
Old May 5, 2015 | 10:22 AM
gaz's Avatar
gaz
My Ride: 530d Msport
Default Help Please
Hi all I'm new to the forum.
Ok today i jumped in my 2006 530d M she started fine my Tyre sensor started waring me that i had a flat so i drove tot the petrol station to fill up with air ( only a mile from where i am) got the station pulled up to the air filler turned the car off. Filled up with air jumped back in the black beauty pushed the fob in pressed start nothing happened. iv been trying for the past hour trying to get her to start but nothing all the lights come on the dash as should as soon as you press the start button the once but won't start please help
Old May 5, 2015 | 02:29 PM
pcy's Avatar
pcy
Does the starter engage (in other words, does the engine try to start)?
If not, check the voltage on battery (or under the hood).
When you push the start button, do you hear a click (starter solenoid engaging)?
Old May 5, 2015 | 07:14 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
did you make sure to put the trans in Park?
Old May 6, 2015 | 03:28 AM
gaz's Avatar
gaz
Thanks iv had the AA out its the starter motor unfortunately
