Help!!! Please
My Ride: 525i
hey guys,
I have a 2004 525i with about 72k on it. About a year ago the car was giving a tremendous amount of white smoke from the exhaust. I took it to a local mechanic and he stated that one vacuum hose bursted and there was some carbon deposits clogging which caused the white smoke and so he fixed. After driving it for about a month everything was good, the car hasn't been driven for the rest of that time. (has been turned on from time to time) About a month ago when i went to turn it on and take it for a drive around the block i smelled something burning in the engine bay. (i believe it is the anti freeze burning but not sure. Everytime i turn on the car the same burning smell comes back. NEED HELP![Excl](https://5series.net/forums/images/smilies/imported/excl.gif)
:exc l:
thanks
hey guys,
:exc l:
thanks
TIP for the future: If your car has to sit undriven for a long period it is better to not start the car, unless you are going to drive it for at least 1/2 hour. You will discharge the battery more by running it just a few minutes than not starting it at all. But far worse, when you start the engine and the engine begins to warm up water vapor is formed. Driving the car 1/2 hour will allow the engine and exhaust system to get hot enough to burn the water vapor off. Just starting the engine for a few minutes and then letting it cool will allow the water vapor to condense to liquid water, diluting your engine oil and leaving water in the exhaust system, promoting rust formation in both the engine and exhaust system.
My Ride: 525i
This car belonged to my mother since 04, last year she got a e92 and I get my license in a couple of month so I'm trying to find out a lot about this car. The car would be turned on once a month if that,(for about 10 min) There are no lights popping up on the dash. The smell is coming from under the hood
Thanks for the replies and tips
My Ride: '07 530i
Does the smell start immediately after starting the engine, or does it take awhile? Do you hear any abnormal noises coming from the engine? Do you see any smoke from under the hood or out of the tailpipe?
My Ride: '07 530i
If that's not it, open the coolant expansion tank (like you're checking the coolant level). Again, do this with the engine off and cold. Take a whiff and you can compare that smell to the smell you get when you start the engine. If that's the smell, get a flashlight and look to see where it's leaking.
If you're not comfortable with doing these checks, take it to your mechanic. He'll find the cause of the smell.
