Help overheating 545!
My Ride: 545 2005 Model. Full spec so happy with as is.(for the moment!)
Please does anyone know a solution to my 2005 545 overheating?
Just changed the water pump & thermostat but no change!!
Curiously I tried putting the air on and looking for the fan to move but the fan didn't move!
Any help would be greatfully received ...
My Ride: M5 SMG
Did you pressure test the system? You can get a reasonably priced kit at Harbor Freight. I think the fan may have an electrically operated clutch, so it may be fine.
My Ride: Sold: 545i, sport package, cold weather, 6MT
Engine: N62
Also, how do you know it's overheating? Warnings on dash? Steam? The two coolant temp sensors are known to fail and are easy to replace. One is on/around the t-stat and the other is on the lower hose running into the radiator on the passenger side. What's your coolant level?
