5Series.net - Forums
-   -   Help needed -Center Console Rear Trim Falling Out (https://5series.net/forums/e60-discussion-2/help-needed-center-console-rear-trim-falling-out-91133/)
CaptH Dec 22, 2009 08:58 AM
My car is a 2007 530i. The wood trim located in the rear of the console with the power jacks and Aux jack keeps falling out. It hangs with the wire attached. Part is
http://www.realoem.com/bmw/showparts.do?mo...hg=51&fg=35
It appears this part is ok since it has clips (one on each side) but it is not clear to me how it holds into place. What piece would have the mating part of the clips? Any help is appreciated.
porsche911targa Dec 22, 2009 09:00 AM
If your car is still within the warranty time and mileage frame, I suggest you take your car to the dealer and let them figure it out. G/L
CaptH Dec 22, 2009 12:42 PM
Already tried that but they didn't fix it. I wanted to be able to define what needs to be done.
Rudy Dec 22, 2009 01:09 PM
I remembered a thread from back in 2004 where Lomag posted DIY instructions on how to change out the trim on the rear console to a wood one since early cars came with a plastic insert.
I found the thread but the links to the pics are broken. Hopefully Lomag will see this and fix his post and the links it contains...
https://5series.net/forums/index.php?showtopic=1187
Tacklebury Dec 22, 2009 03:31 PM
I have the same problem.
I used a tiny amount of superglue and hey presto its fixed!
