5Series.net - Forums
-   -   help needed! 05' 545i NAV retrofit WITHOUT voice command (https://5series.net/forums/e60-discussion-2/help-needed-05-545i-nav-retrofit-without-voice-command-90655/)
dd1818 Dec 12, 2009 12:04 PM
Just picked up a 05' 545i(built 12/04) and I am in some serious need for a OEM navigation.
Yes I did find the PDF instruction on installing NAV on pre-LCI models however I do need to know whether I can do this without the voice command which I don't need.
It seems like mine DOES HAVE
- Prewired GPS Antenna
- Bluetooth(I'm not sure if this is relevant)
and DOESN'T HAVE
- Voice command button next to Idrive
In this case, all I need would be the monitor, CCC and the DVD unit?
Could someone be kind enough to list the parts I would need to order..
Any comments would be helpful. Thanks!!
livefour2day Dec 12, 2009 02:20 PM
I have done this retrofit to Professional Navigation you do not need to have voice commands or the button to do this retrofit it will still work 100% without any problems.
2exclusive Dec 14, 2009 04:24 AM
i wonder if this is possible in the US. i called a dealer and asked them if its possible to retrofit the nav in an 05 545i build 04/05 and they said its impossible. hmmmmmmmmm any insight?
BLooD Dec 14, 2009 04:30 AM
of courses its possable, there a purpose made retrofit kit for it. the dealer don`t want to do it.
545felix Dec 14, 2009 04:50 AM
and DOESN'T HAVE
the voice command is an easy fix, just requires an additional microphone, the replacement button module, and some coding, but no, you do not need it for a full retrofit.
be advised you're looking at $2500+ between parts and coding. scan my old posts for other advice.
