help my steering wheel isn't centering...
Old 03-14-2008, 03:04 PM
dekzaa96's Avatar
Unhappy
hi guys, for some reason my steering wheel is not centering when i am driving around. I'm planning to take it to the dealer but the problem is i just recently install a sport suspension and put on 19in wheels. Do you guys think the dealer might come up with some BS excuse to not fix my car? thannks for all reply
Old 03-14-2008, 03:08 PM
DrLev99's Avatar
What do you mean by a sport suspension? After-market springs/shocks? If you altered any aspect of the suspension, your suspension warranty is null and void. You will have to pay for any issues associated with the suspension and future problems if they occur. Expect to pay for the alignment. The 19" wheels don't make a difference regarding the warranty.
It would also help to know if your car has active steering or not. And please add your location to your profile.
Old 03-14-2008, 05:07 PM
dekzaa96's Avatar
I had H&R sports springs installed and my car does have active steering wheel. Thanks
Old 03-14-2008, 05:31 PM
GQuK545i's Avatar
My Ride: Carbon Black 545i
You should first check if your rims were balanced right first before you bring it to the dealer.
Old 03-15-2008, 03:41 AM
snkpkp's Avatar
My Ride: 2005 530i Individual, DVD Package, HUD, Bluetooth, Comfort Seats, SR, etc
from what I understand you AS needs to be re initialized , or your alignment is off, but thats unlikely , I did read someone else's car on this board had a tilted steering wheel after service and they just needed to re initialize the AC by Progman and it was fine in less than 30 mins.....
Old 03-15-2008, 07:49 AM
ukr
ukr's Avatar
My Ride: 530i n52
Whenever you do any kind of suspension work you always have to get alignment done, even if you're putting back original parts.
Old 03-15-2008, 08:07 AM
mtw1116's Avatar
My Ride: E60 Bimmer, Sports Package, Premium Package, Black/Black, Xenon Lights, 20
Model Year: 2005
I think you just need an alignment.... Good luck!!!
Old 03-15-2008, 08:29 AM
dekzaa96's Avatar
thansk for all reply but my car was like this before i install the springs......
Old 03-15-2008, 09:40 AM
DrLev99's Avatar
I hope your dealer is aware of that! I had the same problem, and my dealer was aware, so when I dropped it on H&R's, they knew the springs were not the cause. They aligned it for free after the drop. I just hope your dealer knew your wheel was off-center prior. If so, they might hook you up.
Old 03-16-2008, 09:28 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
I know this sounds obvious but do a search using "reset active steering" in the Google box and you'll see more information about what snkpkp said above...
I should add that although this may center your steering wheel, you might want to have the alignment checked too since you had suspension work done.
Quick Reply: help my steering wheel isn't centering...
