help,my e60 is over fueling
My Ride: BMW 525D M Sport
Hi everyone, can anyone help me. my e6p is running very heavy on fuel. am getting frm 15-17 mpg. i am getting 140 miles from half a tank. can eveeyone tell me what they get from half a tank. my car is 525D.
ihave serviced it, got tge egr valve cleaned and got the air mass sensor checked.
I just got the injectors manually check.. all is in order.. only thing that cums up when they pluged into the car is.. the battery sensor.
I dnt know what to check next.
The car drives spot on... Please help.. cheers
My Ride: 2007 525xi
Who is servicing your car? They're stumped? Or are they just throwing parts at the problem?
And seeing as it's a 525D... I've seen people here easily get 60+ MPG out of those. Something is most definitly wrong.
I've seen a common problem to be the thermostats, but those will throw a code...
What type of driving are you typically doing? Diesels need a warmed-up engine to get good efficiency out of it. If you're frequently doing local/city stop-and-go driving on a cold engine, that'll also detract from your MPGs. Though probably not by that much I'd think.
Just throwing some ideas/thoughts out there.
Have you tried resetting the mileage indicator after a fill up? The fuel economy posted in our cars is cumulative, so you are seeing the avg fuel economy since it has been reset. Try doing that and see if it helps.
thesalboy
04-08-2015 09:13 AM
