5Series.net - Forums
-   -   HELP with identifying sensor (https://5series.net/forums/e60-discussion-2/help-identifying-sensor-151987/)
RatedTooReal Sep 25, 2021 12:47 PM
Need help what identifying a sensor that was chewed off and destroyed, Pictures below show everything I need help with. Some knowledge of what this sensor is called and what it does would be great,
https://cimg8.ibsrv.net/gimg/5series...a6f8ec56bb.png
This is the sensor that was chewed off.
https://cimg9.ibsrv.net/gimg/5series...a52523b66a.png
I took the sensor out to inspect it more but I also noticed that this metal pipe it’s attached to go to the front of the car near the fan and has a cap I can twist off (circled in next picture)
https://cimg2.ibsrv.net/gimg/5series...a7f94b365.jpeg
That nozzle is connected to the same sensor I’m clueless about
https://cimg9.ibsrv.net/gimg/5series...9c45bc13e1.png
Picture for better perspective, sensor is located on passenger side behind and below the coolant tank
https://cimg6.ibsrv.net/gimg/5series...6a2dd5558f.png
The chewed off sensor
kd7iwp Sep 25, 2021 01:06 PM
That metal pipe is an air conditioning line so that sensor would be a high or low pressure switch, I’m not sure which.
RatedTooReal Sep 25, 2021 01:09 PM
ok so my Fan is stuck on high it literally turns on full speed when I start the car and stays on, do you think this sensor could be the reason? Because I have already installed a brand new water pump and coolant temp sensor and bleed the coolant system and fan still stays on high ,
twh Sep 25, 2021 05:40 PM
Yes, you munged up the A/C pressure sensor and I'm pretty sure the car now thinks the system is over-pressurized and is running the fan to try and reduce the refrigerant gas pressure in the system.
twh Sep 25, 2021 05:48 PM
BTW, the nozzle you circled in red is the high pressure port for the A/C.
silviufuicu Sep 29, 2021 06:06 AM
check https://www.realoem.com/bmw/enUS/select
