HELP with identifying sensor
Old Sep 25, 2021 | 12:47 PM
RatedTooReal's Avatar
My Ride: 2008 528i
Default HELP with identifying sensor
Need help what identifying a sensor that was chewed off and destroyed, Pictures below show everything I need help with. Some knowledge of what this sensor is called and what it does would be great,
This is the sensor that was chewed off.
I took the sensor out to inspect it more but I also noticed that this metal pipe it’s attached to go to the front of the car near the fan and has a cap I can twist off (circled in next picture)
That nozzle is connected to the same sensor I’m clueless about
Picture for better perspective, sensor is located on passenger side behind and below the coolant tank
The chewed off sensor
Old Sep 25, 2021 | 01:06 PM
kd7iwp's Avatar
My Ride: 2009 535xi Touring 6MT, 2019 i3s
Engine: N54
That metal pipe is an air conditioning line so that sensor would be a high or low pressure switch, I’m not sure which.
Old Sep 25, 2021 | 01:09 PM
My Ride: 2008 528i
ok so my Fan is stuck on high it literally turns on full speed when I start the car and stays on, do you think this sensor could be the reason? Because I have already installed a brand new water pump and coolant temp sensor and bleed the coolant system and fan still stays on high ,
Old Sep 25, 2021 | 05:40 PM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Yes, you munged up the A/C pressure sensor and I'm pretty sure the car now thinks the system is over-pressurized and is running the fan to try and reduce the refrigerant gas pressure in the system.
Old Sep 25, 2021 | 05:48 PM
twh's Avatar
twh
Engine: N52
BTW, the nozzle you circled in red is the high pressure port for the A/C.
Old Sep 29, 2021 | 06:06 AM
silviufuicu's Avatar
My Ride: e60 523i
check https://www.realoem.com/bmw/enUS/select
Alex_Bro_Chill
Apr 30, 2020 09:08 PM
pauliehcfr
Oct 21, 2011 07:30 AM
irunthishit09
Jun 10, 2011 01:37 PM
dixon
Jul 26, 2010 01:39 PM
veGa
Jul 10, 2009 09:44 AM
