HELP!!! I CAN'T OPEN MY CAR'S TRUNK W/ A DISCONNEC
Old 03-14-2009, 05:03 PM
jcool10181's Avatar
I was working on the car and needed to disconnect the battery. I accidentally closed the trunk and now I can't get it to open. I've tried the following:
1) Used the manual key on the key hole by the trunk license plate
2) Tried to jump start the car from the terminal under the hood
I called roadside assistance and all they can suggest is to get it towed to the dealership which opens on monday!
Is there any way to open my car's trunk? Please HELP!!!
Old 03-14-2009, 06:25 PM
jcool10181's Avatar
Anyone???
Old 03-14-2009, 06:27 PM
JSpira's Avatar
I can't imagine how it wouldn't open with the key. Are you sure you are using the right key? Are you sure you turned it far enough?
Old 03-14-2009, 06:30 PM
BlaSTiWi's Avatar
You may need to access the manual trunk pull via either split folding rear seat or manually remove the rear seat.
Gene's Avatar
he's got a M trunk finisher, no key hole..
Old 03-14-2009, 06:32 PM
C's Bimmer's Avatar
Gene - John said he used the key hole by the license plate. Nothing.
Old 03-14-2009, 06:34 PM
Gene's Avatar
, thanx for the correction C, my fault
Old 03-14-2009, 06:44 PM
jcool10181's Avatar
I believe the split folding rear seat is an option feature which my car doesn't have. Now how can i manually take out the rear seats?
Gene, I took out the M trunk finisher to access the key hole.
Old 03-14-2009, 06:47 PM
EBMCS03's Avatar
anyone read the instruction manual? there has to be a way... I'm just too lazy to read it haha
Old 03-14-2009, 06:50 PM
Gene's Avatar
rear seat removal..
http://forums.e60.net/index.php?act=attach...st&id=10619
Quick Reply: HELP!!! I CAN'T OPEN MY CAR'S TRUNK W/ A DISCONNEC
