HELP hood gap.
1 Attachment(s)
This sh** looks ugly.
How can i fix it? |
turn your adjusters all the way down. there is one on each apron. it looks like a 1" circular rubber plug. turn it all the way clockwise and see what that does for you.
Originally Posted by KyleB
(Post 1576340)
(Post 1576340)
(Post 1576340)
Whats up KyleB I remove them and no difference. |
Originally Posted by BostonJon
(Post 1576357)
funny, mine looks exactly like this. I remember noticing if after i loosened the front bumper cover to take out the headlights. from what I recall, there is quite a bit of play in the front bumper as you tighten down the bolts. have you loosened the bumper lately?
Was involve in a accident left of the bumper, fender and hood where gone. Insurance replace everything. |
Originally Posted by Kewill0360
(Post 1576368)
hood gaps cont;
I have mtech front bumper I got from umnitza last June and I noticed the same type of gap. I guess I'll try those adjuster also
QUOTE=Kewill0360;1576325]This sh** looks ugly. How can i fix it?[/QUOTE] |
(Post 1576387)
in that case, I might suspect the use of non-OE parts that dont have the same tolerances
When you open the hood, you will find this rubber seal that runs along the front of the car. Remove that seal (pry it up) and under it you should find some torx screws. Loosen those screws, and you should be able to pull your bumper up a bit to meet up with the hood.
http://zoppp.net/screenshots/2016/03/DSC08048.jpg |
