Help with explaining diagnostic values
Hello..
So, i have a 523i e60 2008 model that are sometimes when the engine is cold not just right. The rpm drops up and down and the car (engine) starts to shake.. after a little while it stops and the engine is going like normal, around 650-700 rpm. What is exactly the rpm value the engine is suppose to run on ideling ? A friend of mine took a diagnostic and got these results : current kilometer reading: 135391 km __________________________________________________ _________ comment line 1: comment line 2: __________________________________________________ _________ $error locationNr: 12521 $error locationtext: 30E9 nitric oxide catalytic converter, aging 610A0A2B0708000300421105100332815302A4421102028202 421101028202210001270202748D8180828020150B122C00 Error: 1(10) No.: 12521 30E9 nitric oxide catalytic converter, aging error type: 1 (4798 ) low memory capacity readines Flag: (16 ) Test conditions fulfilled error status: (35 ) failure presently available, OBDon-board diagnosis debounced MIL - Status: (48) failure does not cause warning lamp show light (MIL) class : ; frequency: 0; entry at km: (1.): (2.): (n.): __________________________________________________ _________ $error locationNr: 12190 $error locationtext: 2F9E thermic oil level sensor 610A0A2B0708000300421105100332815302A4421102028202 421101028202210001270202748D8180828020150B122C00 Error: 2(10) No.: 12190 2F9E thermic oil level sensor error type: 2 (4350 ) oil level too low readines Flag: (16 ) Test conditions fulfilled error status: (32 ) failure presently not available, OBDon-board diagnosis not debounced MIL - Status: (48) failure does not cause warning lamp show light (MIL) class : ; frequency: 0; entry at km: (1.): (2.): (n.): __________________________________________________ _________ $error locationNr: 12049 $error locationtext: 2F11 radiator blind, top 610A0A2B0708000300421105100332815302A4421102028202 421101028202210001270202748D8180828020150B122C00 Error: 3(10) No.: 12049 2F11 radiator blind, top error type: 8 (4336 ) no communication readines Flag: (16 ) Test conditions fulfilled error status: (32 ) failure presently not available, OBDon-board diagnosis not debounced MIL - Status: (48) failure does not cause warning lamp show light (MIL) class : ; frequency: 0; entry at km: (1.): (2.): (n.): __________________________________________________ _________ $error locationNr: 11015 $error locationtext: Unknown error location 610A0A2B0708000300421105100332815302A4421102028202 421101028202210001270202748D8180828020150B122C00 Error: 4(10) No.: 11015 Unknown error location error type: 8 (4369 ) check sum unequal calculated value readines Flag: (16 ) Test conditions fulfilled error status: (32 ) failure presently not available, OBDon-board diagnosis not debounced MIL - Status: (48) failure does not cause warning lamp show light (MIL) class : ; frequency: 0; entry at km: (1.): (2.): (n.): __________________________________________________ _________ $error locationNr: 11014 $error locationtext: Unknown error location 610A0A2B0708000300421105100332815302A4421102028202 421101028202210001270202748D8180828020150B122C00 Error: 5(10) No.: 11014 Unknown error location error type: 8 (4369 ) check sum unequal calculated value readines Flag: (16 ) Test conditions fulfilled error status: (32 ) failure presently not available, OBDon-board diagnosis not debounced MIL - Status: (48) failure does not cause warning lamp show light (MIL) class : ; frequency: 0; entry at km: (1.): (2.): (n.): __________________________________________________ _________ $error locationNr: 11003 $error locationtext: Unknown error location 610A0A2B0708000300421105100332815302A4421102028202 421101028202210001270202748D8180828020150B122C00 Error: 6(10) No.: 11003 Unknown error location error type: 8 (4369 ) check sum unequal calculated value readines Flag: (16 ) Test conditions fulfilled error status: (32 ) failure presently not available, OBDon-board diagnosis not debounced MIL - Status: (48) failure does not cause warning lamp show light (MIL) class : ; frequency: 0; entry at km: (1.): (2.): (n.): __________________________________________________ _________ $error locationNr: 11391 $error locationtext: 2C7F Lambda probe behind catalytic converter 2, trimm control 610A0A2B0708000300421105100332815302A4421102028202 421101028202210001270202748D8180828020150B122C00 Error: 7(10) No.: 11391 2C7F Lambda probe behind catalytic converter 2, trimm control error type: 2 (4202 ) exhaust fume behind catalytic converter too lean readines Flag: (16 ) Test conditions fulfilled error status: (32 ) failure presently not available, OBDon-board diagnosis not debounced MIL - Status: (49) failure would cause warning lamp show light (MIL) class : ; frequency: 0; entry at km: (1.): (2.): (n.): __________________________________________________ _________ $error locationNr: 10705 $error locationtext: 29D1 misfirings, cylinder 5 610A0A2B0708000300421105100332815302A4421102028202 421101028202210001270202748D8180828020150B122C00 Error: 8(10) No.: 10705 29D1 misfirings, cylinder 5 error type: 1 (4096 ) by means of fuel switch-off readines Flag: (16 ) Test conditions fulfilled error status: (32 ) failure presently not available, OBDon-board diagnosis not debounced MIL - Status: (49) failure would cause warning lamp show light (MIL) class : ; frequency: 0; entry at km: (1.): (2.): (n.): __________________________________________________ _________ $error locationNr: 10703 $error locationtext: 29CF misfirings, cylinder 3 610A0A2B0708000300421105100332815302A4421102028202 421101028202210001270202748D8180828020150B122C00 Error: 9(10) No.: 10703 29CF misfirings, cylinder 3 error type: 1 (4096 ) by means of fuel switch-off readines Flag: (16 ) Test conditions fulfilled error status: (32 ) failure presently not available, OBDon-board diagnosis not debounced MIL - Status: (49) failure would cause warning lamp show light (MIL) class : ; frequency: 0; entry at km: (1.): (2.): (n.): __________________________________________________ _________ $error locationNr: 10700 $error locationtext: 29CC misfirings, several cylinders 610A0A2B0708000300421105100332815302A4421102028202 421101028202210001270202748D8180828020150B122C00 Error: 10(10) No.: 10700 29CC misfirings, several cylinders error type: 1 (4096 ) by means of fuel switch-off readines Flag: (16 ) Test conditions fulfilled error status: (32 ) failure presently not available, OBDon-board diagnosis not debounced MIL - Status: (49) failure would cause warning lamp show light (MIL) class : ; frequency: 0; entry at km: (1.): (2.): (n.): _________________________________________ Can anybody please take a look at this and give me their opinion on what the problem is ? Thank you :) Edit: i have more tests results if its necessery, |
The last one I also had with the same symptoms. I changed my spark plugs and all was ok. The first one is also interesting because of the cat converter. I would change the plugs then clear codes and see which ones return.
I'd erase the existing diagnostic codes and drive it till the next malfunction. The codes above could be long gone, and rather misleading.
Thank you for the replies.
i can see on the service reports that in mai the coils was reaplaced due to the same problem i am experiencing now.. The plugs and all filters was also replaced.. but what about the lambda and nox sensors ? since its only ( i think so) when its cold, could the sensors make this kind of trouble ? the logs are deleted and i am having a new diagnostic on thursday.. Hope something good will come out of it. |
| All times are GMT -8. The time now is 11:50 PM. |
