Help with explaining diagnostic values
Hello..
So, i have a 523i e60 2008 model that are sometimes when the engine is cold not just right.
The rpm drops up and down and the car (engine) starts to shake..
after a little while it stops and the engine is going like normal, around 650-700 rpm.
What is exactly the rpm value the engine is suppose to run on ideling ?
A friend of mine took a diagnostic and got these results :
current kilometer reading: 135391 km
__________________________________________________ _________
comment line 1:
comment line 2:
$error locationNr: 12521
$error locationtext: 30E9 nitric oxide catalytic converter, aging
610A0A2B0708000300421105100332815302A4421102028202 421101028202210001270202748D8180828020150B122C00
Error: 1(10) No.: 12521 30E9 nitric oxide catalytic converter, aging
error type: 1 (4798 ) low memory capacity
readines Flag: (16 ) Test conditions fulfilled
error status: (35 ) failure presently available, OBDon-board diagnosis debounced
MIL - Status: (48) failure does not cause warning lamp show light (MIL)
class : ; frequency: 0; entry at km: (1.): (2.): (n.):
$error locationNr: 12190
$error locationtext: 2F9E thermic oil level sensor
Error: 2(10) No.: 12190 2F9E thermic oil level sensor
error type: 2 (4350 ) oil level too low
error status: (32 ) failure presently not available, OBDon-board diagnosis not debounced
$error locationNr: 12049
$error locationtext: 2F11 radiator blind, top
Error: 3(10) No.: 12049 2F11 radiator blind, top
error type: 8 (4336 ) no communication
$error locationNr: 11015
$error locationtext: Unknown error location
Error: 4(10) No.: 11015 Unknown error location
error type: 8 (4369 ) check sum unequal calculated value
$error locationNr: 11014
Error: 5(10) No.: 11014 Unknown error location
$error locationNr: 11003
Error: 6(10) No.: 11003 Unknown error location
$error locationNr: 11391
$error locationtext: 2C7F Lambda probe behind catalytic converter 2, trimm control
Error: 7(10) No.: 11391 2C7F Lambda probe behind catalytic converter 2, trimm control
error type: 2 (4202 ) exhaust fume behind catalytic converter too lean
MIL - Status: (49) failure would cause warning lamp show light (MIL)
$error locationNr: 10705
$error locationtext: 29D1 misfirings, cylinder 5
Error: 8(10) No.: 10705 29D1 misfirings, cylinder 5
error type: 1 (4096 ) by means of fuel switch-off
$error locationNr: 10703
$error locationtext: 29CF misfirings, cylinder 3
Error: 9(10) No.: 10703 29CF misfirings, cylinder 3
$error locationNr: 10700
$error locationtext: 29CC misfirings, several cylinders
Error: 10(10) No.: 10700 29CC misfirings, several cylinders
Can anybody please take a look at this and give me their opinion on what the problem is ?
Thank you
Edit: i have more tests results if its necessery,
comment line 1:
comment line 2:
Thank you
The last one I also had with the same symptoms. I changed my spark plugs and all was ok. The first one is also interesting because of the cat converter. I would change the plugs then clear codes and see which ones return.
Thank you for the replies.
i can see on the service reports that in mai the coils was reaplaced due to the same problem i am experiencing now..
The plugs and all filters was also replaced..
but what about the lambda and nox sensors ?
since its only ( i think so) when its cold, could the sensors make this kind of trouble ?
the logs are deleted and i am having a new diagnostic on thursday..
Hope something good will come out of it.
timmay77
Sep 24, 2015 09:38 AM
DetailersDomain
Detailing Forum
Sep 3, 2015 07:08 PM
