5Series.net - Forums
-   -   Help: e60 stock tires (https://5series.net/forums/e60-discussion-2/help-e60-stock-tires-79394/)
gurp99 Jun 18, 2009 07:49 AM
Hello, Just found out that one of my back tires needs to be replaced because there is a nail in it and it is too close the edge. The tire size is 225/50/17 for the front and back, but i wanted the back to be bigger, would 235/50/17 fit on the back two tires good? would that cause any problems with the stock alloy rims?
:huh: Thank you
thefonehomedave Jun 18, 2009 08:51 AM
:huh: Thank you
wont hurt mate, if you go for 235/35/17's profile will be lower so they'l look better. same on front when they are ready... happy days.
CWS530 Jun 18, 2009 08:57 AM
:huh: Thank you
You could, but you'll have a bit more bulge on the sidewall. It's pushing it on a 7" rim. To stay closer to spec, a 235/45/17 would be better. You won't be able to rotate F/R if you go staggered. Not sure it's worth it for 10mm.
gurp99 Jun 18, 2009 10:32 AM
So a 235/45/17 would be better for the back two tires.. Thanks
CWS530 Jun 18, 2009 10:40 AM
Yes, given the caveats.
