Help: e60 stock tires
My Ride: BMW e60
Hello, Just found out that one of my back tires needs to be replaced because there is a nail in it and it is too close the edge. The tire size is 225/50/17 for the front and back, but i wanted the back to be bigger, would 235/50/17 fit on the back two tires good? would that cause any problems with the stock alloy rims?
Thank you
Thank you
My Ride: bmw e60 530dse, full sports grey leather, sat nav, bluetooth, adaptive headlights, adaptive suspension, zenons, chiptuning box, + usual refinements.
Thank you
Thank youContributors
Thank you
Thank you
My Ride: BMW e60
So a 235/45/17 would be better for the back two tires.. Thanks
Originally Posted by CWS530' post='915788' date='Jun 18 2009, 11:57 AM
You could, but you'll have a bit more bulge on the sidewall. It's pushing it on a 7" rim. To stay closer to spec, a 235/45/17 would be better. You won't be able to rotate F/R if you go staggered. Not sure it's worth it for 10mm.
socale39
Sep 5, 2023 08:30 AM
chadillac2000
42
Sep 13, 2017 11:15 AM
