Help with codes
Old 02-06-2023, 05:00 PM
donpb's Avatar
My Ride: '06 530i N52
Static reading does not tell the entire story. I see no load test or histogram.
08535 (02-07-2023)
Old 02-07-2023, 05:44 AM
habbyguy's Avatar
My Ride: 2006 530xi (Touring)
I see a load test (result). This problem isn't the battery. Follow seanjordan20's good advice.
Old 02-07-2023, 03:08 PM
donpb's Avatar
That's not load result. @seanjordan20 is stating the same as me. I never said it was the battery but he and I both said check the battery. Load test has a rebound critique that literally no one checks.
Old 02-08-2023, 07:31 AM
habbyguy's Avatar
What is the CCA (Cold Cranking Amps) result if not a load test? Maybe I'm missing something...
Old 02-08-2023, 09:49 AM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
A load test is different from a CCA test. A CCA test is statically performed. A load test tests the battery to see how it performs under load. You can have a battery test good with a CCA test but bad under load. This is why you should always load-test a battery to ensure it's good. There's also a cranking test. Load test is also called charging test. They both achieve the same thing.
Old 02-08-2023, 03:05 PM
Crepitus's Avatar
My Ride: 2007 525xi
Just an update I disconnected the RDC and all of the k line faults are gone. Can I assume that I what is at fault. I took it apart and it's corroded. It is also missing pins. I don't know if they are supposed to be there or not.
Old 02-08-2023, 04:04 PM
twh
twh's Avatar
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Good job. Possible the car had water in the trunk in the past. Common issue with all the modules there. There is a bulletin that the modules should be relocated to the fender or tail light area.
Old 02-08-2023, 04:06 PM
Model Year: 05 530i
Engine: 3.0 M54
Is that where I told you to start looking when I responded to you on FB?
Old 02-08-2023, 05:40 PM
Crepitus's Avatar
My Ride: 2007 525xi
It is. Thats why I started there. I heard you can code it out for ftm. Can I do that with a scan tool
Old 02-08-2023, 05:47 PM
Model Year: 05 530i
Engine: 3.0 M54
No, you need BMW software tools installed on a laptop or surface pro.
Quick Reply: Help with codes
