Help with codes
Old Feb 6, 2023 | 09:37 AM
Crepitus's Avatar
My Ride: 2007 525xi
Default Help with codes
I don't know what I got myself into but it's overwhelming. Just picked up this 2007 525xi and it has all these codes. Can someone help? The car drives fine but would like to get it working correctly.
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
I let you know what to do on FB. You need to start checking connectors. We see it all the time. Owners get good deal cars but lack the knowledge and tools to diagnose what's wrong with the cars. It's going to cost you more to fix because of it.
Old Feb 6, 2023 | 11:40 AM
habbyguy's Avatar
My Ride: 2006 530xi (Touring)
You probably already got this advice too - reset all the codes and see which ones come back. Often, a car that experienced a low-voltage situation (aka "dead battery") will have set all sorts of nonsensical codes. If you clear them and they don't come back, don't get your knickers in TOO tight a twist.
Old Feb 6, 2023 | 12:08 PM
Crepitus's Avatar
My Ride: 2007 525xi
I reset them a few times and this is what keeps coming back
Old Feb 6, 2023 | 12:34 PM
You're being overwhelmed by all the codes but I assure you your main issue is you K-line fault. Find the bad wire or connector and fix it. The rest are normal codes and only require simple parts. Focus on the K-line fault and make sure your battery is good if not it needs to be changed immediately because once a BMW deems a battery not sufficient it shuts down modules.
Old Feb 6, 2023 | 01:00 PM
donpb's Avatar
My Ride: '06 530i N52
IBS Missing won't help the battery much. Battery could be damaged already.
Old Feb 6, 2023 | 03:12 PM
Crepitus's Avatar
My Ride: 2007 525xi
Battery is brand new and I had it tested. It's good. Where do I start looking for fault?
Old Feb 6, 2023 | 03:13 PM
Crepitus's Avatar
My Ride: 2007 525xi
Thanks for the advice.where should I start looking?
Old Feb 6, 2023 | 04:40 PM
donpb's Avatar
How was it tested? I've had supposed brand new batteries be bad. What did the battery histogram show?
Old Feb 6, 2023 | 04:47 PM
Crepitus's Avatar
My Ride: 2007 525xi
