Help with code 28e7
Old Mar 6, 2023 | 02:31 AM
Acebell's Avatar
My Ride: 2005 BMW 525I
Default Help with code 28e7
I have a 2005 Bmw 525i with the 2.5l m54 engine. I'm trying to figure out what's causing the code. It's referring to o2 sensor bank 2 sensor 1. But I changed all the sensors. Could a vacuum leak cause the code? When I run the engine & when I turn the engine off I hear the engine sounds like gasping/sucking air. My check engine light is on.
Old Mar 6, 2023 | 08:31 AM
habbyguy's Avatar
My Ride: 2006 530xi (Touring)
What is the PXXXX code that's associated with the 28E7 code?
Old Mar 6, 2023 | 09:19 AM
Acebell's Avatar
how do I see that? I just got the code from inpa.
Old Mar 6, 2023 | 09:21 AM
habbyguy's Avatar
You can use a regular OBD reader / scanner. There are a number of PXXXX codes associated with the 28E7 BMW code, all of them pointing to different things.
dieseljim
Aug 9, 2020 02:09 PM
TPIOlds
May 26, 2017 05:48 AM
Original
Feb 6, 2014 09:09 AM
CesarE.
Jan 27, 2014 06:18 PM
Persian_535i
Nov 10, 2012 02:49 AM
