HELP, Clutch issue...Clutch wont engage, cant start car
Originally Posted by Mrsosoo' post='970585' date='Aug 9 2009, 07:20 PM
damn no it isnt CPO, its a 2004 with 65k miles.... I hope I don't have a big bill and that its something simple.Thanks for the responses and I'll let you guys know what happened
My Ride: BMW 545i
Originally Posted by pjinca' post='970590' date='Aug 9 2009, 10:22 PM
If you find the thread about mechanics in NYC you will find the guy I used to use. He won't over charge - just in case - and good luck.
thanks bro
Originally Posted by Mrsosoo' post='970525' date='Aug 9 2009, 09:45 PM
The clutch was pinned to the floor and wouldn't come back up. I had to pick the clutch up off the floor with my hand.
My Ride: BMW 545i
Originally Posted by unknown' post='970879' date='Aug 10 2009, 03:10 AM
that usually means you have air in the line... check the rear chamber of the break fluid reservoir. if its low or empty, then you found your problem. now you have to find out if you have a break in the line or it was just low. good luck
i hope its only that. Thank you for the info, you guys have been helpfull!!!
Kalvin
My Ride: BMW 545i
out of curiousity.....are used cars also covered under the lemon law assuming any issues with the car within the first 3 months have to be fixed by the dealer you bought it from??? Car was bought in NJ btw
Depends on the state, NY is pretty good about that, not sure about NJ - since all I bought there was new. Here in Cali you are pretty screwed, they give you 30 days and at least 3 times to repair the same issue (which isn't hard for the dealer to make it last more than 30 days).
My Ride: BMW 545i
wow sounds like it can turn into a sticky situation. I just called the dealer and I'm waiting on a response now. Thanks for the fast reply
Good luck man, hope it all works out. Since it has been a mere month and half you should make a stink, threaten them until they fix it, with legal action, investigative reporters (every town has one of those "consumer watchdog" reporters), anything to make them fix your issue.
My Ride: BMW 545i
damn right, I'm gonna fight for this....thanks again for the advice, the response time in this forum is greatly appreciated
Kalvin
