Help! Changed front tire now lights on...
Old 04-01-2008, 06:47 PM
zakattak20's Avatar
Unhappy
Hello All,
This will sound very newbie but I just recently changed my front drivers side tire to a general exclaim uhp tire and now the dynamic stability control (I believe thats what is what displaying) icon is flashing warning me. The icon picture display looks like one tire is taller than the other. The other three tires are toyos but the toyo on the passengers is of course the same size as the general uhp (245/18 in the fronts). I was trying to replace the drivers side front with the same toyo but they were unavailable. My suspension is off too of course, steering wheel is not center and sways off. Should I just get another general tire on the other side to even out ? Alignment, but is one tire really taller than the other even though the same size ? Any input would help, thank you in advance!
Old 04-02-2008, 05:30 PM
zakattak20's Avatar
can you anyone please help? just on what is causing this or what to do? thanks again
Old 04-02-2008, 05:55 PM
Gene's Avatar
I always thought it's better to change at least 2 tires at a time to have at least some sort of balance/symmetry? Did you reset/check the TPM's?
Old 04-02-2008, 06:21 PM
Westcoast M5's Avatar
It's dangerous to have two different tires!! Get an matching front tire asap!!
Old 04-03-2008, 04:16 AM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
Yep.
And that's why your car is trying to tell you something...
Old 04-03-2008, 06:57 AM
545felix's Avatar
My Ride: 05 545/6
Originally Posted by zakattak20' post='554586' date='Apr 1 2008, 10:47 PM
Hello All,
um, you're missing a rather important number there. the middle number (245/40/18) is the height of the tire as a percentage of the width, so in this case 40% of 245mm. if that middle # doesn't match the 245/40/18 on the other front toyo there's your problem.
Even if they do match, manufacturers vary a little bit in sizes, but I wouldn't think that enough to throw off your steering. I'll be willing to bet you got a 245/35 or 245/45 General tire.
-felix
Old 04-03-2008, 01:07 PM
new-kid's Avatar
My Ride: E61 530d Touring, May 2004
Its not just the rated tyre size that matters - it is the actual size also.
By maths, the distance a tyre goes per revolution is 3.14 x diameter. So if a new tyre has say 10mm tread and a worn one 2mm, then surely the new one will travel 8x2x3.14 = 50mm further per turn than the old one. Hence confusing the heck out of the ABS / traction control sensors.
Always change in pairs unless can match age, make/compound and size
Old 04-03-2008, 09:42 PM
530_nz's Avatar
My Ride: AmethystGrau '03 530i
Get a picture of the error symbol and post it here.
Old 04-03-2008, 10:26 PM
zakattak20's Avatar
yes its a 245/35/18 but on both sides....so would you think getting of course the matching tire and an alignment for a start?
Old 04-03-2008, 10:31 PM
delje08's Avatar
My Ride: 545i
get the other matching side then reset your TPM. then you should be fine.
Quick Reply: Help! Changed front tire now lights on...
