HELP!!! BMW 2005 530I FRONT BUMPER ISSUE...
Old 07-21-2009, 06:08 AM
Mrsosoo's Avatar
My Ride: BMW 545i
Originally Posted by jamesr2' post='948790' date='Jul 21 2009, 09:34 AM
Can I go to BMW dealer and ask them to fix it like u said?
I think youd be better off going to your local body shop
Old 07-21-2009, 07:11 AM
Kzang's Avatar
I don't think you have to take off the bumper to adjust the gap.
Old 07-21-2009, 08:13 AM
jamesr2's Avatar
You think it's totally fine... right? Im so paranoid ...
Old 07-21-2009, 08:18 AM
theXman's Avatar
My Ride: 2004 530i
You should bring it back to the place that fixed the front end for you last time. Dealer wouldn't do it unless the body work has been done by them.
Old 07-21-2009, 08:25 AM
Bob525D's Avatar
The gap looks too big to me, get a bodyshop to take a look if you are not sure about have a go yourself.
Kzang's Avatar
What I meant was to adjust the gap size between the hood and front bumper you don't have to take off the bumper to do this.
I saw a BMW service guy do this to another car with a wrench on both side under the hood.
But like I said originally, I don't think it looks bad at all, but if you want to ahve it adjusted it should be an easy fix.
Old 07-29-2009, 07:28 PM
Allen's Avatar
My Ride: 535i 6-speed
I would like to know how to adjust this gap on mine...it looks wider than it should. I looked and it seems that the hood just needs to close/latch down further. With the hood closed and latched, I can actually push it down a bit further to close the gap to an acceptable amount.
There is a rubber stop on the left and right side under the hood that can be turned to snug the hood up once it is latched closed...but it seems like the (2) latches (they latch the "hooks" mounted to the left and right underside of the hood) need to be lowered a bit so the hood has to go further down (closer to the bumper) in order to latch.
Anybody done this or know how to do it?
Old 07-30-2009, 05:52 PM
jamesr2's Avatar
Mine wasn't at the hood.... it was actually the front bumper...
It needs to be adjusted upwards... not lowering the hood......
Im pretty sure about that even tho I didn't fix it yet...........
Old 07-30-2009, 07:30 PM
Allen's Avatar
Raising the bumper or lowering the hood...either way works the same as long as you maintain alignment with the other pieces...ie headlights, quarter panels, etc. You can close that gap some by lowering your hood and then some more by installing washers under the bumper mounting bolts to raise the bumper.
The only thing you have watch out for is getting the hood too low to be aligned with the headlights. I am in the process of raising the bumper by using the "washers under the bolts" trick mentioned in another thread on here.
Old 08-01-2009, 03:42 AM
jamesr2's Avatar
I hope you get a good result on that Just let me know how it ended up. ! I want to try too if it works!
socale39
09-05-2023 08:30 AM
Kasmo
05-07-2019 03:30 AM
sweetnlowe60
04-07-2015 01:23 PM
Sai Paladugu
03-23-2015 01:23 PM
rkilpa
03-04-2015 09:10 PM
Quick Reply: HELP!!! BMW 2005 530I FRONT BUMPER ISSUE...
