help! annoying rattle from turning stalk
Old Jul 27, 2011 | 07:18 AM
dantheman1's Avatar
Ever since I brought my car to the dealer to have the steering angle sensors replaced (thus far the only downside to the active steering option), there has been this annoying rattle that I thought was coming from the steering column. Well, today, I was using the turning stalk and noticed the same rattle. I finally narrowed it down to the "check" button on the left steering stalk. Although it works fine, it's loose and rattles whenever there's a slight vibration or if I tap it, unlike the BC button underneath it. Does anyone know if the button can separate from the stalk and be replaced/greased and reinserted, or is the button and stalk all one piece? Thanks!
Old Jul 27, 2011 | 07:37 AM
NavarroOne's Avatar
My Ride: E61 535d carbon black m-kit panoramaroof with beige nasca interior and wood trim. 172m rims. DimSport Race, SB, SAT
This thing drove me nuts for 6 months. Then I took advice and sprayed a bit of BMW's rubber treatment on the switch. It's been another 6 months I reckon and I haven't heard a single rattle since then. So save yourself the trouble; don't take anything apart or try to wedge anything in the gap. The spray works wonders and if you don't have it, I bet silicone spray will do the same job. If you have neither, go buy the rubber spray from a dealer and give the door weatherstrips a good helping while you're at it. Your car will love you for it.
Old Jul 27, 2011 | 08:32 AM
dantheman1's Avatar
After a bit of searching, turns out this is a somewhat common problem on the e60. I ended up sliding a tiny piece of black electrical tape in the crevice between the bottom of the check button and top of the turn stalk, with sticky side down. I found this out from this link: http://www.m5board.com/vbulletin/e60...-rattle-3.html . The real solution however is for BMW to replace the entire stalk. I might bring this up when I go in for my next service. For now though, the cabin is as quiet as can be.
Old Jul 27, 2011 | 08:46 AM
flyingpuck's Avatar
You drive a 2008 E60, so it's still under warranty, tell the dealer to fix (replace) it!
gmcclintock
10
May 29, 2017 10:56 PM
srogers535x
Aug 5, 2015 08:48 AM
patallen
Aug 1, 2015 04:52 PM
Padilla74
Jul 19, 2015 03:08 PM
CVTBenhogan
Jul 13, 2015 06:46 AM
