HELP AC Hight to LCI AC
I saw many DID from ac basic to lci ac or hight ac but i can't make mine run i cut pin 21 and put 12v on it from the small two pin connector and nothing.My engine vent is blowing as much is it can and i have some error codes in AKHA and no AC working for me.Can someone give some sort of DID for this retrofit(car is coded with SA534)
Hi
You cut pin 21 wire (brown/blue). The cut wire pin 21 that come out of the electrical block goes to + red wire The cut wire pin 21 that's on the loom side goes to - brown wire. |
Originally Posted by Pepe Le Pew
(Post 1590521)
| All times are GMT -8. The time now is 02:26 AM. |
