Help
My Ride: Gone Waiting
Hi ,
I know i have been posting again and again for the battery drain problem , but now it does not make a difference whether if left the key or not in the key switch i still have high rate of battery discharged. Really do not know what is causing this.
So guys i know some of you guys are expert , please help me with that problem .
Thanks
Thanks
Banned
My Ride: A Car
open the right side of the trunk compartment. Look at the battery and then there should be a clear hole with a color. check the color. u may need to fill the battery up with some dihydrogen monoxide
Originally Posted by turboawd' post='981749' date='Aug 19 2009, 02:20 AM
did you use a multimeter to see if there is a current draw on the battery while the car is off?
looking at your sig, did you rule out your stereo equipment?
My Ride: 520d LCI, old engine, manual, black dakota, platingrau II, standard (242?) rims.
Are you sure that the new battery was fully charged? Have you driven a long haul?
