HELP!
My Ride: 2004 530i Black/ Smoked LED side markers/ CF kidney Grille/ Shadowline Trim/Miro 346 V2/General Exclaim 19"/CF Badges/H&R Sport Springs/ Koni FSD shocks/struts/R1 Concepts Drilled & Slotted Rotors/ Hawk Pads/ Mtec V2 lights/
Heres the situation, my girlfriend was messing around with the stuff in my glove box and shut it, no biggee. Then she was going to open it again and it wouldnt open. So i thought it was locked, got home tried to open it, no go. The lock seems to be loose in the box itself. Has anyone had to break into there glove box and if so how.....?
My Ride: 2004 BMW 545i Sport Package, Titanium Gray II Metallic, Wheel Style 124
any independent shop will charge you close to $120 plus they might not have the part... the dealer replace this in 4 minutes and only charged me for the piece $20
Originally Posted by theXman' post='955829' date='Jul 27 2009, 05:57 PM
It s your gf's fault. Bring it to dealer and send her the bill.
gl on the fix!
#! - You need to get her under control NOW
#2 - Cut her off until she pays to get it fixed
#3 - Learn how to beg
thanks for the tips guys, ill shrug off some hard work tomm to get to the dealership...and then send the bill to my curious gf!
My Ride: G30 M550i
Model Year: 2018
You may be able to open by inserting the key and using this to open the lock. I've had problems with mine where on side of the hinge came loose with the small round locating pin falling out. Got it all back together and working, but the lock barrel can be lose sometimes and using the key to re-insert can help.
