5Series.net - Forums
-   -   Help 530i 04 Couple of things creating problems (https://5series.net/forums/e60-discussion-2/help-530i-04-couple-things-creating-problems-151141/)
BBoy123 Sep 19, 2020 02:00 PM
Another day another problem with my 530i. F*** thIs car.
1: Wipers Error on the Dash and wipers going off by its own.
2: Windows up or down Not working.
3: IBS sensor or comfort access is killing my battery (as diagnosed by some other Forum) everyday over night. Any suggestions are appreciated.
Everytime i have to jump start it to run if the battery is gone low (because something in the Car is staying Awake)
When I turn Off the Car it makes 3 sounds in a repetitive order when key is turned off. 100% those 3 sounds are killing battery overnight.
seanjordan20 Sep 19, 2020 04:40 PM
If you don't know how to test a fuse for a draw pull the fuse to see if it makes a difference. The easiest way for you to find out which system is causing your issue.
donpb Sep 19, 2020 04:49 PM
You need to isolate the culprit and / or get someone to read the BMW codes (or buy a DTC reader).
RedGorilla Jun 9, 2021 06:33 PM
Have you looked at the MPM under the spare tire? If it got damaged from water it can screw with this.
Flguy76 Mar 14, 2022 04:55 AM
is this a manual manual so what cash price for it, that is if u part out.... I need manual for my turbo setup on my 530i
