Help!
Old 04-26-2012, 08:39 AM
pcy
pcy's Avatar
Originally Posted by TheRab
Also just called the dealership for a quote they quoted me $537.00 + the cost of parts for one coil (+$77.00). Also he recommended I have changed all the coils and spark plugs too (at another cost). Sounds like I'm in for about $800-900 if I go with the dealer.
$537 labor to replace ignition coil? That's beyond highway robbery. It takes less than 10 minutes to pull out the ignition coil pack. It it takes more than 15 minutes, that tech shouldn't be working on the car.
As others suggested, I'd first connect OBD-II code reader and check the codes. Very likely, there will be a code related to coil. Throwing parts at the car without reading codes is not a good idea... not for your wallet.
Old 04-26-2012, 08:50 AM
TheRab's Avatar
My Ride: | 2010 535i x-drive | Monaco Blue Metallic | Cream Beige Dakota | 6 Spd Manual | Sport | Cold Weather | Premium | HUD | Navi | Logic 7 |
You guys think the code readers from the the auto store (like advance or autozone) could suffice? Also is it ok for me to drive the car there in this condition? ( distance <1 mile)
Old 04-26-2012, 09:04 AM
jgt
jgt's Avatar
My Ride: E60
Engine: N52
It'll give you the generic code which will probably be enough to go on.
Here's a list of generic codes. I got P0303 when my coil went bad.
http://smogcarsuck.tripod.com/id45.html
I did drive pretty lightly on a single bad coil for about 3 days until my parts arrived.
Not recommended since you might damage your catalytic converter due to excess fuel but my exhaust did not smell noticeably worse than normal. I figured the ECU shut off fuel for that cylinder or at least leaned it out significantly.
I never confirmed whether or not the ECU shuts off fuel completely but no harm no foul and I've passed all my emission tests.
Old 04-26-2012, 02:27 PM
jimadams7's Avatar
Is their a DIY on changing the ignition coil pack don't even know where they are located .its worth knowing just in case it happens
Old 04-27-2012, 05:57 AM
TheRab's Avatar
I am going to go off this video. After watching this I think I know what I'm doing.
hope it helps
Youtube clip
http://www.youtube.com/watch?feature=player_embedded&v=GN618su1psU
Old 04-27-2012, 01:52 PM
TheRab's Avatar
**UPDATE**
So I got the codes read out of my vehicle and its not good news
I had a misfire on cy. 1, 2, 3 [p0301,302,303] and a Random misfire (p0300) but the worry some thing is I got a code for P050B which is the cold start ignition timing. I order three ignition coil packs hoping that it is just the coils on those cyclinders. ::sigh:: I'm not to sure how to proceed from here. Any ideas?
Old 04-27-2012, 03:27 PM
jgt
jgt's Avatar
My Ride: E60
Engine: N52
Three coils going bad at the same time is very unlikely in my opinion. Sounds like it might be something else unfortunately I can't think of what it could be at the moment.
Old 04-27-2012, 03:50 PM
bcromwell's Avatar
According to Bmw n55 code list P050B
The fault is recognized when
the ignition-angle adjustment
is outside the tolerance
range.
Potential problem source(s):
- Poor fuel quality
Which would also cause all of the misfires. Where did your last tank of fuel come from and was car sitting for a few days?
jvme60's Avatar
My Ride: 2004 525i M54
fuel injectors? just a guess...
Old 04-27-2012, 04:15 PM
TheRab's Avatar
range.
- Poor fuel quality
Hmmm my gas comes from BJ's (regular) I'm thinking it could be that, I am low on fuel now (the light just came on) so I'm going to try another place for gas (super grade) and also try some fuel injector cleaner perhaps that can help. I'll keep everyone posted
