Hello, Newbie here. I did search. I am looking at 04 545i vs 530i manual.
My Ride: Working on getting a E60 6-speed
Good morning everyone,
I recently started my search on the E60 545i vs. 530i, I have owned euro cars before, I do understand there is sometimes a possibility for gremlins. I am not afraid as I don't mind working on cars. I found a great deal on one with 150k miles for 5k. I understand that buying this means, replacing suspension, belts, gaskets, fluids, clutch, hoses. Is there anything else I should really be concerned about? Anything major?
My Ride: 530i
Engine: M54
early production V8 E60s (545i) are notorious for oil leaks, and lots of them. also they are known for valve stem seal failure. If I had to choose I would happily forgo the extra power of the V8 and go for the NA inline six cylinder to gain better reliability. I chose my 530i for that very reason. 545i cars are getting dirt cheap, and there's a reason for it. Good luck with whatever you choose.
I also vote for the 530, for same reason over the 545 as K+ the manual makes it so much more fun to drive.
Thank you both, I think after my research you guys are right. I will stick to the 530i.
My Ride: 530i
Engine: M54
Whatever you choose, I'd look for an '04 or '05 (M54 engine) or any N52 powered car with a production date after 11/31/2008. BMW updated the cylinder head to correct a flaw that allowed the lifter bores to run dry causing excessive lifter noise. Cars built after that date should have the updated cylinder head.
Good luck.
My Ride: E60 M Sport 530i
I have an 06 N52,the higher power version (190 kw).....fantastic car.
When i was looking for a 530 i thought at first they were all the lower 160 -170kw power models,i did not know there was a higher power version. Very glad i found out about that,the LCI higher power versions (07 on-wards) have 200kw.
I'm driving Australian delivered euro spec 2006 E60 530i.
I get that part but look at the date of the first post......he was already driving the 535 for two months and asking us re the 545 or 530, that's why I said what I said earlier!
