Hello guys!! Cheers from houston...
My Ride: Blue bmw
Got big dilema,and few options right now..im frustraded whit my 535i 2010.i make a race couple nights ago,n i hit 140/h..and when slowing doing the messege transmition malfunction showed up..say what that heck...so i took it to a shop..but next day that messege wanst there anymore...but still i wet to the shop...ok they tell me...4 -5th gear slipping gears..recomend to replace valve block selenoids, shifter assembly is faulty stereenig paddle shift are defective..mil on mixture problem...so and the wanna charge 1380 $ do that will fix the problem? Or need to take a diferent opinion from other shop? Plz guys need some help![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
My Ride: e60 n54 sport auto
Model Year: 2010
Engine: N54
Do you want another opinion to tell you the same thing? Can you remove the stuck solenoid your self? Can you check the transmission fluid level?
My Ride: Blue bmw
